X1c Nozzle Purge Position Over Chute
Hello,
Is there a way to reset the positioning of the nozzle over the purging “Poop” chute? I have been having a issue, where while purging a piece of the filament will end up over the edge of the chute where is folds over then kinda gets hooked there causing a Filament Buildup / Clog. While looking for solutions for this, I found some videos and noticed others machines when purging are much further over the chute when purging, where my X1c is really close to the left front corner edge. If there is a way to reset the purging location it would greatly help resolve this issue.
Check to make sure that your nozzle isn’t bent.
As @JonRaymond says, we see the calibration line location and purge location affected by a bent nozzle every now and then.
Also check that aren’t bits of filament or other debris that would prevent the tool head from reaching the front corners. The printer drives the head into the corners as part of the homing procedure. You can see it bump into the corners a few times at the beginning of a print.
You may want to check the belt tension. It may home fine but absolute positioning will be off if the belts are loose. But then the print quality would also suffer so this is less likely.
