X1C prints outside the print area. (Just Y axis)
Hi, X1C prints outside the print area for Y axis but it not have a problem in X axis.
Also It performs the nozzle cleaning process in the printing area.
I didn’t find a solution for this issue. I need your helps. Printer don’t give any error or info.
Check that your nozzle is not bent forwards.
Are you using the stock BBL start G-code or changed it ?
Yes, you are correct. My nozzle was bent forward to front side. Thank you for your response. I didn’t think this. I checked more point but didn’t think.
The nozzle may be toast. But the other parts are still good! Spare parts.
I’m having the same problem with my Bambu lab a1 and my nozzle isn’t bent the bed sounds like its ramming into the actual front part of the printer and its driving me nuts can someone please help?
