im trying to get my hands on an x1c but i wanna look at the x1e first
It’s not a correct comparison. These are two very different products with very different target audiences and most importantly, they are supported very differently.
if you can afford the X1E, the wired Ethernet alone is “almost” worth the extra 1K. But the other features such as active chamber heating and wider range of filaments might sway you. However, if these are not important, stick with the X1C.
I’m a P1P owner and I have a number of friends with X1C’s. Personally, I can’t even justify in my own mind the cost difference between the P1S and the X1C but I’m sure that statement alone will generate feedback here. Which is why this is called a “discussion community”. ![]()
| Feature | Bambu Lab X1 Carbon (X1C) | Bambu Lab X1 Enterprise (X1E) |
| Nozzle Temperature | Up to 300°C | Up to 320°C |
| Chamber Heating | None | Active chamber heating up to 60°C |
| Connectivity | Wi-Fi | Wi-Fi and Ethernet |
| Air Filtration | Activated carbon filter | Enhanced industrial-grade air filtration with G3 pre-filter and H12 HEPA filter |
| Supported Materials | Ideal for PLA, PETG, TPU, ABS, ASA, PA, PC, PET; capable with carbon/glass fiber-reinforced polymers | Supports a wider range, including high-performance materials like PPA-CF/GF, PPS, PPS-CF/GF |
| Target Users | Advanced hobbyists, educational institutions, and R&D departments | Professionals in engineering, manufacturing, and design fields requiring high-precision and material versatility |
