X1C XY Banding?
X1C
Details
>4k hours
New XY Belts < 3weeks ago.
File problem noticed
IT+inside+IT.3mf
Slicer
.16 HQ
Supports
Tree Auto
Hybrid
On Build Plate Only
Support Critical Regions Only
Top Z Distance .21
No Other Custom Settings
Sunlu PLA 2.0+
Have no issues, Ive run probably 50 spools of this through the printer.
This is a new issue, I have probably 200hours since the X Y Belt replacement. Ive run calibration twice, directly after the belt swap and just now. No resolution.
How many layers to one full cycle of banding? Not that I’m suspecting anything but the number of layers per cycle may trigger something someone else knows.
It could almost be a nice effect if it was optional, though.
I had a similar effect when using infill type cross hatch with a low wall count. The cycle of the changing orientation exactly matched the banding cycle. I don’t remember the solution exactly anymore. I think increasing wall count and/or changing wall sequence to outer/inner or inner/outer/inner solved it.
