X1E pieces broken when moving head out of purging
Hi all, brand new in the forum, but have had the X1E since release, without any problems up till now.
I got an issue with the hot end fan after running ASA, it might have happened anyway, but this is not the reason for the post.
When i was about to remove the hot end i moved the buildplate down, then i moved the head straight towards the front from the purging / cleaning position, a bang, and i found some plastic pieces and a screw.
I cant find where this belongs, which also meens that i have no idea of how severe the problem is or what to replace.
I hope the link for the photo works…
https://share.icloud.com/photos/05f9bJw5q6I98U8mnSEoWcGjQ
If anybody can help me identify the parts i would be super grateful.
Copy/Paste:
Welcome to the forum.
This is one of the screws from the part cooling fan mount. This seems to break off on higher mileage printers. I’ve had it happen on my highest hour count X1C.
I’ve not had a mount break, but I have developed a crack.
Printing a replacement now, while the printer still works.
And wondering what other parts I should be making…
I tok me some time to actually check the issue, the responses are fully correct, it seems to be a week design and maybe a bad material choice.
In my case it was the top screw, the bang was prabably the screw that had stuck to the magnet and was jamed in between the purge station walls.
Will have to order a new head front part.
A lot of thanks for the help and support.
