Printing a bunch of PETG with PLA support interface, I finally got the dreaded heat creep on the aux side. The PTFE tube was not seated all the way for the aux extruder, so the filament made a little loop in the void. The soft filament also got stuck in the cutter.
I have it all back together, with fresh PTFE tube for the aux extruder. FWIW I bypassed the buffer a while ago (aux spool mounted externally on the left), and also installed 45-degree aux fan duct diverters to prevent warping.
I wonder how to avoid this issue moving forward! I will print with the lid propped up to prevent chamber heat buildup, but wonder what folks have done to prevent this problem.
This is also addressed in this topics and others, even in the Bambu Wiki in the clog section.
The problem with the heat in the aux path and basically in every place inside the printer box, is because PETG and PLA has different softening temps, printing temps and heat bed temps.
Then the printer uses as guide for the box air/heads/nozzles the PETG temps. And if you have enough time/long enough print, the temp will creep up to the AUX nozzle and paths.
And even if you open the box, like front door and the lid, the temp could creep via the other nozzle. We have other topic for that around, in which we have discussion on possible options for unloading filament from the AUX during the print.
In general if you use different material with lower softening temp, you need to make sure that the temps around the loaded filament are as required. Or you will get clog soon or later. This is why I have pointed you to the given topic. You can see similar problem in the H2 section also.
So either you need better and smarter cooling while the PLA is inside/loaded. Or you need to load print and unload fast. Before the creep happens. Ideally some combination from both.
BTW here is a topic in Bambu wiki:
And they show settings for PETG + PLA: Set the air deflector angle higher than the air outlet (deflecting position; left image) when either of the following is true:
You’re printing with PETG only.
The model’s main filament is PETG and the support filament is PLA.
