my x2d is now failing build plate detection every single time, I have cool plates, engineering, and textured PEI plates from BBL and it’s always bugging out at hte beggining of each print. My H2C is perfectly fine. I have the latests updates etc. what’s going on? is this my unit or a general bug?
I think, build plate detection hates light coming in from the right side. The reflection will overlay the image from the qr code. Maybe that’s the case where you have installed it?
My X2D complains about build plate detection very often as well and as it has pointed out by itself, it is caused by light from the outside. Blocking incoming light has solved the issue. I may need to install some sort of blinds to the front door
Its looks like all old plates with small and framed “QR” are unrecognizable. Only new textured PEI plate with BIG & UNFRAMED QR works. Covering side windows doesnt help :(…..
You are absolutely right. When you want old style plates to be detected, then you need to put a sticker with new qr code on.
There are a bunch of models that you can 3d print. I find it a little pointless to 3d print the stickers, when you can simply use a regular printer, especially when you want to use the plate at up to 120°C. In this model P2S build plate codes - ArUco/QR Labels (Niimbot) - Free 3D Print Model - MakerWorld, the first comment contains PNGs. You have to scale them to the correct size, but at least for the cool plate super tack works perfectly fine for me.
But even with new codes, sometimes the printer doesn’t recognise it when external light reflects on the plate so that it over brightens the qr code.
Size could be an issue. Can you compare the size against the code on the plate that came with the printer?
The X2D is using the camera that sits at the front left corner, that you can also watch or use for time lapses. It sees the code at quite steep an angle. So if it is too small or light from outside causes glare, then the camera has no chance to properly read the code.
I read that the X2D doesn’t recognize QR codes and that those are only for the X1 Carbon, could be totally wrong but it exceeded my patience level so I turned off plate detection on mine so that I could use BIQU plates without hassle.
Based on my conversation with support when I recently bought the plates they mentioned that I might have been sent old plates. However base don my reading I thought the x2d just doesn’t detect any of the plates yet other than the PEI plate, not sure.
Those are both old style plates, so you need new style stickers to have X2D recognise them correctly. I think, at the moment there are only a few new style plates available from BanbuLabs. I don’t think, any smooth plate with new QR codes is out yet.
I suggest to download the image files from the comments in the link above, rescale them to the same size as the working codes and print them on paper. Then you can glue them onto your plates with the old code.
I’m not sure if the codes are the same as for H2 printers? If yes, you can also buy ready to use stickers on AliExpress.
I am getting ready to print and try, my concern though is the actual code part is exactly the same, I assumed that the code would be different. I will let you know if the printed one works.
