X2D horrible top layers
Ran the Flow Dynamics (K factor) or “pressure advance” calibration not the Flow Rate calibration. They are different.
I hope this helps you solve your issue, online there JSON presets, which you can download and straight insert to your printer, those are filaments that are fully tuned and calibrated for your printer, there might not be a need for a flow dynamics calibration, I hope this helped because it also helped me, also try slowing down your top layer maybe the same as the first layer.
if none of this works (it most likely should) then just enable ironing and tune it.
:smiley:
