My X2D’s left nozzle was causing a clicking on extrusion. I’ve torn the whole thing apart and can see the root cause of the problem. The top of the hot end is about 1mm to the left of the cutter opening. I’ve tried reseating the heating assembly. Everything seats nicely. Bambu support hasn’t been able to figure out why. Anyone have this problem and found a solution?
I had that issue with the Right Nozzle on my X2D & nothing seemed to fix it. I couldn’t get it to “seat” properly so it wouldn’t pass the alignment check at the beginning of a print
I was still able to print single colour stuff from the left nozzle, but that’s NOT why I purchased the X2D, as I can print from a single nozzle on my P1S. Eventually I decided to swap the left & right nozzles, installing my spare new nozzle on the Left & swapping what I knew was the good left nozzle into the right side. That solved my issues & now I have another “spare” nozzle as well as a HF 0.4mm waiting to be installed
