I just unboxed and set up my new X2D combo today. I’m having some issues with the auxiliary extruder. I’ve already sent a ticket to support, but I’m wondering if anyone else has any ideas how to fix this issue.
Prints using the main extruder and AMS work perfectly fine. I tried a print that uses both extruders, and it fails nozzle offset calibration whenever I try to start a print. Running nozzle offset calibration from the calibration menu works fine, as does high precision nozzle offset calibration. The nozzle offset calibration always fails when I start a print.
I turned off nozzle offset calibration and tried again. This time, the printer printed the first part of the print using the main nozzle, but when it switched to the auxiliary nozzle, the printer stops without showing any kind of error message. The status just says ‘printing’ and the percentage stays the same, without the nozzle doing anything.
I tried a simple print using only the auxiliary nozzle, and I get a “nozzle cleaning failed” error. There is nothing visibly wrong with the nozzle, and filament was able to be loaded and extruded just fine.
I’ve tried the following:
-I’ve updated to the latest firmware.
-I changed the nozzle in the auxiliary extruder to the spare one that came with the printer.
-I’ve checked the nozzle offset sensor, and ensured it was connected.
-I cleaned the nozzle offset sensor.
-I’ve disconnected and reconnected the auxiliary extruder cable.
