X2D - wobbling toolhead
Hello,
I observed significant toolhead wobble with strange clicking noise. I’m aware that the carriage uses a spring-loaded assembly against the upper rod, but compared P2S, the wobble on my unit is noticeably larger and the clicking sound is present only here.
Do you have the same or I have issue with my printer? Please check video with sound :slight_smile:
Jesus. OF COURSE it moves when you grab it and honk on it like that.
At what point in a 3D print does the printer ever see any forces even close to that?
It isn’t a CNC router dude. The toolhead doesn’t need to have zero deflection under heavy loading, it just has to have zero deflection under printing forces, which you’re exceeding by a few orders of magnitude.
I really wonder sometimes what ever possesses people to just grab onto the nearest object and start reefing on it. Like…what? :laughing:
Im not using lot of force reallly. Also I compared to 2 pcs of p2s and no issues like that. Have you watch photos with sound?
I have issue with horrible wall quality. Checked a lot of seeting and problem all time exist. Ive checked ABS PLA PETG all had issue. Even when is decrease acc to 1k.
And I have a lot of experience with 3d printer world. I build up several high speed voron which achaived 30k acc and 600mm/s on outer wall with good print quality.
Im almost sure that problem in my case is related to hardware.
Kinda looks like its missing a bushing or you somehow wore out the bushing.
Printer has less than 100h so rather not worn yet…
Move the toolhead all the way to the right and all the way to the left, do the same thing at each position.
The gantry will probably need to be replaced since everything comes as one part.
Are any of the rods loose?
I tried and each position is the same. The woobling is not beetween bearing and rod there, there is between bearing and toolhead housing.
How did you verify that? Did you remove the covers?
Turns out that mine has a little bit of play too at both shafts, but it seems like less than yours, and print quality is excellent for my X2D.
There was similar report before, you may be able to find the topic. But yours seems to be excessive.
And I think he returned the printer and get new one with same issue.
I do not have such play.
