XY axis homing causes toolhead to hit rear frame
Hi everyone, I’m wondering whether anyone has encountered similar issues.
This problem is usually followed by an HMS error 0300-8005-172918 “Tool head cover has fallen off“
Printer - P1S
When homing in readiness to print a part, the tool head will hit the back of the printer frame with a loud knock. It will attempt this again three times, each time hitting the frame over the filament chute. At this point I get the HMS error. This error can’t be cleared except by restarting the printer.
I have tried re-tensioning the XY belt, cleaning the carbon rods and generally ensuring that all mechanics are free from possible obstruction but the problem still persists.
Hi, I’m having a very similar problem with my P1S.
When I start a print, the toolhead hits the back of the frame hard, moves around a bit, and then hits the back again. It keeps repeating this. In my case the printer doesn’t show any HMS error, but it never gets out of this loop and never starts printing.
So far I’ve cleaned the carbon rods and re-tensioned the XY belts, but the problem is still there. I haven’t found a solution yet.
If you manage to fix it, could you please share what worked? I’ll post an update here if I find the cause.
Thanks!
That sounds like a faulty motor board (MC). To explain it in simple terms: When the printer reaches the end of an axis, the current in the motor increases, and the board detects this and stops immediately. This prevents a crash. If the motor board no longer detects this, then that’s exactly what happens.
I’m guessing this board has a defect - no guarantees, just a preliminary assessment. You can also check to see if the cable is still securely connected and if the contacts are in good condition.
Connector 6, 7 and 11.
However, it could also be due to something else; as I said, this is just a initial assessment. For some, it was also due to defective SD cards that contained corrupted g-code.
Have you opened a support ticket yet?
Thanks for replying. I have since rectified the fault. The problem was caused by the XY motor belt. Re-calibrating the home position for the toolhead by loosening the belt and resetting home fixed the issue.
Thanks for replying. please see my response above for a quick account of the fix:)
