So, new to 3D printing and wanted to try the PETG hotness. I heard PETG can be “challenging,” but I never really knew what that meant, until I started using it.
Excited to print with PETG, I printed something on day one, and then another couple of things a few days later and then, by the end of the week, I had my first massive print failure with PETG.
I did what every new person does with their first failed print, I scoured the Internet, and ultimately chalked it up to wet filament. Everything was going so well and I was hoping not to have to make another investment in a filament dryer.
So, I decided to try what most people say won’t work. I figured if it didn’t work, I’d have to do this anyway, I’d just go ahead and buy a purpose-built filament dryer.
I bought a quality dry box, a hygrometer and likely more desiccant than I need. I put the filament in the dry box along with the hygrometer and the desiccant and, within several hours, the hygrometer showed 0% humidity. I kept the dry box sealed for almost 2 weeks.
Today I opened the dry box, connected the PETG filament and proceeded to print a simple model that failed spectacularly last time; it was as close to perfection as I can expect.
While I can’t say this will work for everyone, I can say this has definitively worked for me. It’s possible this is related to my specific environment, which usually hovers a bit under 40% humidity, but I did make this post because I wanted to reiterate that this does work. I don’t know if I would have had the same results if I removed the PETG from the dry box within a few days or week instead of almost 2 weeks, but maybe someone else can chime in.
If you want a quick run down of what I use and how I use it, I took my first stab at designing a simple hygrometer holder for my needs and documented this and related at Hygrometer Bracket Ezy Storage 32L 33.8qt Dry Box by Bink3D - MakerWorld.
Cheers!
