Z axis callibration changes every print
I run manual Z axis calibration code and then start the print.
1st layer prints perfect. Everything is great.
Print finished and i send another file to print and verything is screwed up at this point.
I now have to calibrate Z again by moving the platform by about 0.5mm again.
After that, it will stay 0.5mm too high for all prints causing problems.
If i manually calibrate X axis again, after print, it will change again and i have to add another 0.5mm each time until i ran out of bed height.
Why is that ?
I am using custom machine start and end code
Here is start:
M960 S5 P0
;===== machine: P1S =====
;===== date: 20240229 =====
;===== Version 6 - FINAL =====
;===== start G-Code by Schmudi =====
;===== !!! use at your own risk !!! =====
;===== P1S firmware: 1.05.02 =====
;===== AMS firmware: 00.00.06.40 =====
;===== reset machine status =================
G90
M17 X1.2 Y1.2 Z0.75 ; set motor current to default
M290 X40 Y40 Z2.6666666; Use Babystepping
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
M73.2   R1.0 ;Reset left time magnitude
M1002 set_gcode_claim_speed_level : 5
M221 X0 Y0 Z0 ; turn off soft endstop to prevent protential logic problem
G29.1 Z{+0.0} ; clear z-trim value
M204 S10000 ; init ACC set to 10m/s^2
;=============turn on fans  =================
M106 P1 S125 ; Part fan
M106 P2 S50 ; AUX Fan
;M106 P3 S125; Chamber fan BAMBU
M710 A1 S255; MC-board fan automatic
;===== heatbed preheat and home ====================
M1002 gcode_claim_action : 2
M140 S[bed_temperature_initial_layer_single] ;set bed temp
M104 S100 ; set extruder temp - low value to avoid blobs while homing
M190 S[bed_temperature_initial_layer_single] ;wait bed temp
M1002 gcode_claim_action : 13
G28 T300; Homing - permit 300deg temperature
M400 ; wait for finish homing
;===== prepare print temperature and material ==========
M1002 gcode_claim_action : 7
M104 S{nozzle_temperature_range_high[initial_extruder]} ;wait extruder temp
G91
G1 Z10 F1200
G90
M975 S1 ; turn on mech mode supression
G1 X67 F12000
G1 Y240
G1 Y265 F3000
;===== wipe nozzle ===============================
M109 S220 ;set extruder temp
M1002 gcode_claim_action : 14
M975 S1
M106 P1 S255
G1 X65 Y230 F18000
G1 Y264 F6000
G1 X100 F18000 ; first wipe
G29.2 S0 ; turn off ABL
G0 Z5 F12000
G1 X60 Y265
G1 X100 F5000; second wipe
G1 X70 F5000
G1 X100 F5000
G1 X70 F5000
G1 X100 F5000
G1 X70 F5000
G1 X100 F5000
G1 X70 F5000
G1 X90 F5000
M400
G1 Z10
G29.2 S1 ; turn on ABL
M975 S1 ; turn on vibration supression
;===== bed leveling ====================
M1002 judge_flag g29_before_print_flag
M622 J1
    G29 A X{first_layer_print_min[0]} Y{first_layer_print_min[1]} I{first_layer_print_size[0]} J{first_layer_print_size[1]}
    M400
    M500 ; save cali data
M623
;===== prepare AMS ==========
M1002 gcode_claim_action : 4
M620 M
M620 S[initial_extruder]A   ; switch material if AMS exist
    G1 X120 F12000
    T[initial_extruder]
    G1 X54 F12000
    G1 Y265
    M400
M621 S[initial_extruder]A
M620.1 E F{filament_max_volumetric_speed[initial_extruder]/2.4053*60} T{nozzle_temperature_range_high[initial_extruder]}
M975 S1
M106 P1 S255
G1 X65 Y230 F18000
G1 Y264 F6000
G0 Z5 F12000
G1 X60 Y265
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X90 F5000
M400
G1 Z10
M106 P1 S125 ; Part fan on
;===== for Textured PEI Plate , lower the nozzle as the nozzle was touching topmost of the texture when homing ==
curr_bed_type={curr_bed_type}
{if curr_bed_type=="Textured PEI Plate"}
G29.1 Z{-0.05} ; for Textured PEI Plate; personal PEI plate - corrct value to your own plate
{endif}
{if curr_bed_type=="High Temp Plate"}
G29.1 Z{-0.00} ; for smooth PEI-plate
{endif}
;======== wait extrude temperature and prefill =============
M106 P3 S220 ; Chamber Fan BAMBU
; M106 P3 S25 ; Chamber Fan NOCTUA
G29.2 S1
M190 S[bed_temperature_initial_layer_single] ;set bed temp
M109 S[nozzle_temperature_initial_layer] ;set extruder temp
M1002 gcode_claim_action : 0
G92 E0
G92 E0.2 F200
G92 E0
;===== wipe nozzle again===============================
G4 P5000
M975 S1
M106 P1 S255
G1 X65 Y230 F18000
G1 Y264 F6000
G0 Z5 F12000
G1 X60 Y265
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X90 F5000
M400
G1 Z10
Here is end
;===== date: 20230428 =====================
M400 ; wait for buffer to clear
G92 E0 ; zero the extruder
G1 E-0.8 F1800 ; retract
G1 Z{max_layer_z + 0.5} F900 ; lower z a little
G1 X65 Y245 F12000 ; move to safe pos
G1 Y265 F3000
G1 X65 Y245 F12000
G1 Y265 F3000
M140 S0 ; turn off bed
M106 S0 ; turn off fan
M106 P2 S0 ; turn off remote part cooling fan
M106 P3 S0 ; turn off chamber cooling fan
G1 X100 F12000 ; wipe
; pull back filament to AMS
M620 S255
G1 X20 Y50 F12000
G1 Y-3
T255
G1 X65 F12000
G1 Y265
M621 S255
M104 S0 ; turn off hotend
M622.1 S1 ; for prev firware, default turned on
M1002 judge_flag timelapse_record_flag
M622 J1
    M400 ; wait all motion done
    M991 S0 P-1 ;end smooth timelapse at safe pos
    M400 S3 ;wait for last picture to be taken
M623; end of "timelapse_record_flag"
M17 S
M17 Z0.4 ; lower z motor current to reduce impact if there is something in the bottom
{if (max_layer_z + 100.0) < 250}
    G1 Z{max_layer_z + 100.0} F600
    G1 Z{max_layer_z +98.0}
{else}
    G1 Z250 F600
    G1 Z248
{endif}
M400 P100
M17 R ; restore z current
M220 S100  ; Reset feedrate magnitude
M201.2 K1.0 ; Reset acc magnitude
M1002 set_gcode_claim_speed_level : 0
M17 X0.8 Y0.8 Z0.5 ; lower motor current to 45% power
Please help me understand what is the issue here.
The reason why i use this googled custom code is because original code printing unwanted garbage and extrudes unwanted amounts of material and basically takes forever to start the actual print job.
I tried that start gcode this morning and had the same issue, it’s missing something in the start sequence where it isn’t saving the z offset correctly, likely something changed in the firmware since February. I didn’t have time to troubleshoot it, so can’t say what it is yet
