Hi all,
My A1 (approx. 2000 print hours, bought second-hand) worked fine for a long time, but recently started scraping the plate. I’ve gone through pretty much every standard fix and I’m running out of ideas, so I’d appreciate any input.
Symptoms
- After homing, the nozzle drags across the plate during travel moves
- Wavy/ruffled first layer, blobs on layers 2–3, prints getting knocked off
- Occasional printer freezes
- Flow rate calibration returned an unusually low value (0.88), most likely because the nozzle was too low
Key finding
Placing a sheet of paper (~0.1 mm) under the nozzle during homing stops the scraping. So the printer seems to detect plate contact ~0.1 mm too low.
Hotends tested (all original Bambu Lab)
- 2x hardened steel 0.4 mm – scraping
- New hardened steel 0.6 mm – scraping
- Stainless steel 0.2 mm – worked fine at first, then started scraping as well
What I’ve checked / ruled out
- Factory system printer preset, Generic PLA, Textured PEI selected in Studio, correct side of the plate up
- Plate and magnetic base cleaned (IPA + dish soap)
- Bed leveling enabled for every print, full calibration run multiple times
- Same issue before and after the latest firmware update
- Two different filaments, diameter verified at 1.75 mm
- Z lead screws cleaned and greased, X/Y rails cleaned and oiled
- X gantry level: 0.15 mm difference left/right
- No play in the bed or the toolhead
- Toolhead USB-C cable reseated on both ends, no visible damage
- Nothing hanging below the toolhead – it’s the nozzle itself that drags
- Heater assembly mounting screws (4) retightened per the wiki – first layer actually got worse afterwards
Current workaround
Start G-code offset for Textured PEI changed from the default G29.1 Z{-0.02} to G29.1 Z{-0.015}.
- -0.02 = scraping
- -0.01 = slightly too high
- 0 / +0.02 / +0.04 = too high, prints lifting off
Even with -0.015 it’s not fully consistent.
Support status
I have an open ticket. Support pointed to the eddy-current contact sensor and its connection to the toolhead board, but they need logs first. Log uploads via Bambu Handy keep failing (“Incomplete”).
Questions
- Has anyone had a failing eddy-current contact sensor / toolhead board on the A1? What were the symptoms and what part fixed it?
- Has anyone seen the probing go off gradually like this across all hotends?
- Any tips for getting log uploads via Handy to actually complete?
Thanks in advance!
