Been using the p1p for 2 days, and I have noticed that one of my z rod axis screw wasn’t sitting inside the bearing. I’ve seen some post mentioning screw rods popping slightly but mine was way off and wobbly in the z direction. Further inspection shows that the timing pulley at the bottom of the printer is also somehow loose in the z direction. I currently started a ticket in the customer support and asking for a replacement unit as im pretty sure this is a manufacturing problem. However, i would also love to see if anyone experience something similar in the meantime! Do you guys think this issue is sufficient for a request of a replacement? Its been 3 days since i’ve bought it.
FWIW I saw someone on reddit with a similar problem just today: Reddit - Dive into anything
thanks! The issue does look quite similar, hopefully there is a fix for it.
Same problem here? Did you fixed it and how?
