I have previously posted about my issues here: Printhead cover magnets unglued and cant claim warranty but this wasn’t the end of my problems so I am making a more detailed timeline of my ownership of a Bambu Lab X1C with AMS.
We received the printer on the 20th of March and had a jam the next day which was later fixed since they did not respond to my ticket. After a few good prints, there was that head crash on 28.3. and after arguing with the support for a few day printer was packed on 7.4. I got no answer from support before I posted on the forum but then they wanted to fix it real quick so here is a free tech tip for anyone who isn’t getting responses from support for a few days, forum is where it looks like support spends most of the time. Another issue was that I replaced the cold plate sticker with the high temp one and that was damaged by the head as well as the magnetic surface for it, both parts of the housing, cutter, and the hotend were bent. Firstly they only offered me 30€ credit for me to buy a new front cover but after some arguing we agreed that I would send back the printer and get a new one. I demanded they send me a replacement high temp plate instead of the cold one and wanted some compensation for lost filament, spoiler I got none of that. I unfortunately didn’t have all the original packing material which was a point of friction with support but when they sent me the packing video it wasn’t even for the material I got originally.
Now I will speed thru some dates:
12.4. was the day I finally sent back the printer since they took 3 days to get me a shipping label which wasn’t even good at the end and I had to deliver the box to the post office instead of then arranging pickup.
15.4. rejected delivery at their end
17.4. they received my printer for inspection before sending a replacement
24.4. I bugged them for the new printer shipping details which they said were already set
26.4. the date they sent the replacement printer
3.5. we received the new printer but now without any high temp plate and we were out of ours
11.5 finally received a high temp plate and were able to continue printing
They said that this process will take around 2 weeks but it took more than a month so big red flag here.
The new printer hasn’t made one good print and after going back a forth with the support they insist that a printer that is made for printing carbon filaments and comes with a 0.4mm nozzle and has a setting for a 0.16mm layer names OPTIMAL is not made for this. I know it is recommended to use a 0.6mm nozzle but it says it is OK with 0.4 even though not recommended and the setting 0.16 is named optimal but they claim that you shouldn’t go under 0.2.
This is what i was getting so I sent them my project and they “fixed it” by putting it on a 0.2 mm layer and changing the settings to be a bit more conservative as well as changing the infill.
And this is the result of their file and when I said that it was not ok this was their response:
And yes the filament was dried correctly despite being new.
I think I don’t have to prove anymore that the printer has issues as well as their after-sales system and I don’t know what to do. They closed my ticket 3 times despite me repeatedly saying to leave it open until we get the issues resolved. Even after that, I am scared to send the printer back since I don’t think I will get all the money back for all the spare parts since they messed up with the plate before despite me being so specific and I don’t even know if I can send it back since this is acceptable for them.
RECAP:
Anyone considering buying this printer gets a Prusa i3MK4 it looks way better (I worked with 3 MK3s all with over 3000h of use and they worked way way better)
Anyone having issues with support just stand by what they should do or just let the forum know how are they treating you.
And for the BambuLab team:
Issue a recall for faulty magnets and fix the design of them (free tech tip: if you insert them from the side then cant be pulled out).
Fix your support and start reading what people write (if I said I have dried the filament don’t recommend it as a solution, etc.)
Stop false advertising (i have AI detection on high and it detects spaghetti only a quarter of time, if it can’t print on a 0.4 nozzle remove it)
And if I press extrude on the screen only the extruder spins but not the AMS and the extruder melts filament quite often and then clogs.
I could go on for longer but if this is fixed it will be a good step forward.
