I wanted to purchase some of the Carbon Effect sheets and was looking in the Bambulab shop for a bare Springsteel Plate to stick the sheets to.
They are not available for sale separately, You only get a bare Springsteel Plate if you buy the Plate and Sheets Combo.
I don’t understand why they would do it this way.
I’m not interested in any of the other 3D effects sheets, only the carbon.
So I wrote support a message and they said I should stick the Carbon Effect Sheet to one of the PEI sheets I already own for my X1C.
I then told them that I can’t believe they expect me to ruin i.e. the cold plate or the Engineering plate by sticking another sheet over it.
Is everybody else just buying the Plate and Sheet Combo?
Or does anyone have a link for an extrenal source for a Bare Springsteel plate for the X1C?
You should read this thread as this has been debated thoroughly recently.
You are not alone.
God I wish they would just sell the plate.
Yeah that’s what put me off getting a set, needs a bare plate as an option to buy separately. I’m not going to invest in a set till this is an option or I have a recked plate that needs a new surface but I don’t think that’s going to be soon, my textured PEI plate has over 1500 hours of PETG printing and still going strong.
So there is no way to get those bare spring steel plates from anywhere?
Sure, if you’d like to spend a bit. (I don’t recommend it)
I bought Chinese build plates that had one side smooth under 10 USD.
I’m having exactly the same problem; I’m looking for a raw spring steel sheet without any surface coating. I’ve already reached out to manufacturers in China and suppliers in Europe, but so far, I haven’t received any replies and haven’t found anything. For now, the most cost-effective solution is to buy a ready-made smooth PEI sheet and peel off the glued PEI layer. But I’m still searching…
