6 printers stopped working all at once. can't z home
Hi
today all 6 of my A1 minis stopped working. none of them can bed level or home Z axis. i am weirded out that this happens across 6 printers all at once. they have all been running fine yesterday.
i have tried everything from:
factory reset.
calibration.
checking nozzle
the suggestions from this topic: A1 mini Z-axis homing failed
and this wiki: Homing and leveling failure troubleshooting guide for A1 series | Bambu Lab Wiki
i am at a loss for what to do now
Support ticket.
What you’re describing is exceptionally odd.
Following this on the off chance this is some wild edge case.
An update.
After a few hours og browsing youtube and forums for help i have retried and have managed to get them all to run again though i am uncertain as to what solved the issue though i have a suspecion.
It was rather chilly in my workshop when I started and the issue occured, and I did dial up the heat while working on the printers.
My theory at the moment would be that the eddy sensor is temperature sensitive and that the printers started working again after reaching normal room temperature. I will try replicate it again when the printers are done and then turn down the heat again to see if the problem comes back.
Follow up.
I tried to recreat the scenario again, but its inconclusive. i got 3 printers that run as normal regardless of temperature, 1 that sometimes fail bedlevel/z homing, 1 i have managed to start twice since and then 1 that only started that one time after.
The answer i got on support ticket, says temperature shouldn’t have that kind of influence.
