A1 extruder clicking
Hi all, I received my brand new A1 last week and been printing most days. On one day I heard some clicking noises and saw that my extruder wheel wasn’t turning as it should. So far I’ve tried the following:
  • Push needle into nozzle
  • Various cold pulls
  • Took my extruder apart and cleaned the two gears that push the filament
Even after all those things I still can’t manage to push filament out. And when I do get to start a print it starts clicking at some random place and time into the print.
I used Bambu Lab PETG and PLA Basic on their plastic spool as well as Polymaker Polyterra PLA.
I’m literally lost for words and can’t figure it out so any help/insight would be much appreciated.
Here’s a link to a video I’ve made of the sound: https://youtube.com/shorts/olg1s3ZtuI0?si=ErH8UXYHZU0Y_Hk1
Did you remove the hotend to see exactly where the jam is? Some photos of the interior of the hotend would be nice. Did you try increasing the hotend temperature above that necessary for PETG and pushing the filament? Perhaps the PETG has caused some partial jamming that has gotten worse when using the other filaments that require a lower temperature.
Yes, I have removed the hotend several times and also tried heating it up a bit higher. The hotend seems perfectly clear as I can shine a flashlight through it.
Hi! I suggest you do a coldpull
While I appreciate you taking the time to reply, I’ve performed various cold pulls as stated in my original post.
Hello - I also have this problem. The wheel clicks/stops and the printer prints nothing. I have had the equipment for 2 weeks and have already written to support. I printed less than 1kg of filament and the prints were perfect. Currently the equipment is useless, I refilled the nozzles and still the same thing. I went a step further and ordered new nozzles, but it’s not about ordering new equipment after such a short period. Have you solved your problem yet?
make sure your hotend is seated properly i have found one time i had it slightly off and i think the filament was feeding into the top mteal guide which in turn would make it click since the filament couldnt enter the hot end properly
Most likely, I had garbage in the filament feeder - a hole right before it was inserted into the nozzle. I did Cold Pull three times, blew out the filament feeding tube and everything works fine and there is no crackling. With a flashlight, a toothpick, compressed air and a manufacturer’s cleaning rod - you can do it quite efficiently. Of course, I was panicked and in the meantime I ordered 3 new nozzles from the manufacturer’s website :> well, whatever it is… learning must be expensive :stuck_out_tongue_winking_eye: The video turned out to be the most helpful YouTube " Unclogging Your Bambu Lab A1 Mini 3D Printer: A Step-by-Step Guide to Clearing Jams"
Hi, did you get to fix your issue?
I just had this same looking and sounding problem.https://forum.bambulab.com/t/what-is-this-clicking-by-my-extruder/89238
Check the screws on the Hotend Heating Assembly. My problem was fixed by the second part of this wiki
(https://wiki.bambulab.com/en/a1-mini/troubleshooting/print-issues-troubleshooting)
There are four screws on the back of the Heating Assembly that hold its 2 parts together. When I opened mine up, one screw pop-out at me (completely undone) and the other 3 were loose too. The wiki has pictures and instructions for tightening the screws.
Might be worth a check. I had never taken the Hotend Heating Assembly off my machine before so it was like this from the day I got it.
Hi! I’ve got the same problem, seems to be depending of the filament but I ignore wich parameter. Have you the problem again?
Make sure the filament cutter is in the right position. If you’ve taken the extruder apart, the filament cutter may not have slid back into the proper position during re-assembly, you have to pay attention to it.
So I had this same problem. It was clicking and the nozzle part was moving when it clicked. My prints started coming out like ■■■■!
I solved it by two things: 1. I used the de clogger tool and pressed everything out of the nozzle area. 2. I started manually turning the little wheel or extruder on the face area that pushes the filament through. I noticed that as I spun it the wheel part inside would sometimes stop. I think there was a jam or not lubricated fully. (Which would explain why it would have gaps since filament wasn’t getting pushed through) I kept twisting both directions and it finally turned without stopping.
Printed out the boat perfectly on test where prior was like it had been sooo hole ridden.
Good luck if it’s happening to you!
Problem in screws of nozzle holder. Tight all 7 of them. 3 front 4 back
I think this might be it. I tried cold pull, inserting needle it would start the print then suddenly give extruder error. I have tightened the hotend screws(THEY WERE LOOSE AFTER AROUND 200hrs of printing)
Clicking noise from A1 and filament not being laid down nicely is possibly the thermostat. I had this issue and once changed it works like it is brand new again.
I have something similar happening, but the nozzle is moving while the filament is going thrugh it at the time of printing. Prints fail and first layer is abysmal. I can’t print anymore.
I am in the same boat as well. Im 3 weeks in on this new A1, did several successful prints before this happened. It happbed after discovering I had a clogged nozzle. I have done cold pulls, used the provided needle in the hot end, and checked the screws for the nozzle holder. I am waiting on new nozzles to see if this fixes the issue. Also I am going to try and increase the temp from 220c to 225c and see if that makes any difference.
Did you ever find a solution? I did everything you did, including tightening the 4 screws, cleaning the entire extruder twice, doing automatic and manual flow dynamics and calibration. I still have the clicking issue while printing, huge globs form when purging filament, and my prints are under extruded.
