A1 Power OFF itself
I have noticed this issue since 2 months ~
Sometimes, the printer just turn OFF by itself.
I don’t know really why this happend.
Today, I wanted to start a print with PLA-Glow , so I swapped my 0.4mm nozzle to a hardened 0.4mm.
Launched the calibration tests (noise, vibration, bed levelling), no problem.
Then I started the print, and after the starting processs all was good, then , 3 minutes after printingg, the printer suddenly goes OFF (like if you turned it OFF manually).
No more power… (it’s not the first time I had this issue, but now I wanted to post it here, for some help/advice)
The printer wasn’t hot, wich could maybe be something that could cause this issue…
I’m a bit lost about this strange behavior…
Did anyone encounter this issue ?
To answer that, we’d need to know exactly what you mean by “off”: Is it completely powered down, or are the LEDs still on, at least?
If the printer stops printing but the LEDs are still on, it may be due to a defective SD card. The printer is having trouble reading the file and stops printing midway through the job. Fortunately, you can quickly check this by using a different SD card.
If, on the other hand, the printer shuts down completely - meaning even the LEDs go out - there could be many possible causes, ranging from the power supply board to the control board.
Of course, this raises the question: If you’ve had this problem for two months now, have you already contacted support? Is your warranty still valid?
I dealt with this a few months ago. For me, and for you based upon the exact scenario you are describing, the motherboard was short-circuiting and shutting the printer off by itself.
It happens sometimes, in two months I’d say 5 times ~
The printer goes totally OFF, no more power at all, LEDs are off too. Only way to wake the printer up , is to push the power switch on the back (off, then on)
It’s not the SD card cause I use the printer with the wify (it’s boring to switch the card every time you want to print)
I didn’t contacted support, and my printer is now 1year and 7months old. (iirc i got it November 2024)
“Fortunately” it happens more between two prints.
Today it happens just at print start.
Just a quick reminder that the SD card is always in use, even when you’re using Wi-Fi. This is where your transferred data is stored. If the SD card is defective, your printer will no longer be able to print - or stops in the middle of printing.
However, since you said that the LED turns off too, the problem is probably with the electronics. You should therefore contact support immediately. These are problems that you shouldn’t ignore.
This is especially important if you have an A1 (not an A1 mini), as these are known to short circuit and burn out. You don’t need to panic, but you should definitely take care of this issue rather than ignoring it for months.
Thank you for you quick reply , and the link for the video. I just looked it, and now wieving most recent video from this channel about A1 short circuit.
It’s a bit scarry !
As you says, I’ll contact support this weekend, and see what they could do to solve the problem.
I hope they can do something to replace it, without having to wait severals weeks or months.
Sending the ticket to support request a photo or a video, but I don’t have one… Can’t Isend the ticket without that ?
Did you solved the problem ?
If yes ,how ?
(repost cause I didn’t clicked the answer button correctly)
Zdraví. Řešil jsem stejný problém před 2 měsíci. Prohlídka celé elektrického vedení a nakonec byl vadný hlavní vypínač vzadu. Byl uvnitř roztavené plastové části a když se zahřál tak začal jiskřit a vypnul celou tiskárnu. Po opravě už se tiskárna nevypnula sama. Od té doby na zadní vypínač nevypinam. Vytahuji přívodní kabel.
i bought a new motherboard and replaced the old one
This one ?
https://eu.store.bambulab.com/fr/products/toolhead-board-a1-mini
yes
Don’t the problem come from the “Power Board” ?
I’m seaching if there is one for the A1 serie, but couldn’t found it.
I only see some for others printers series.
Or is it a “Power Supply” or a “Power switch” problems ?
It’s strange we can’t see or found some of those products for the A1 serie, or is it me that can’t found those things by searching on Bambu Store ?
PS : my A1 printer had 3 power issues in the last 2 days. Always the same problem, the printer totatlly shut down himself, no more power , LEDS turns off too.
This sounds like a serious electrical issue. There is a very real chance that there is some loose connection inside of your printer board, or an electrical short. If you want to reduce any risk of possible damage to the board, you might want to keep the printer turned off and unplugged until you and customer support can reach some kind of agreement on what it is and how to fix it.
Open a support ticket, they should hear about that
Assuming no other devices on your electric supply are having problems :slight_smile:
Do you have other stuff plugged into the A1 that might be overloading it? Extra camera, extra LED, daisy chained multiple AMS2 pro, etc.
for the ticket they want a picture or a video, but what kind of picture ? Just my printer that is powered off ??
And I don’t have anything more than my AMS lite connected to the printer.
The printer is connected to the same outlet since day1 (I got the A1 combo since November 2024)
I just encouter the issue again today and this time I have recorded it.
So now, a ticket is send with this post link, a little description of the issue plus the video.
Wait and see, I really hope they could fix my printer, even if I have to replace a board myself before the warranty ends.
Some feedback about this issue.
After sending a ticket to explain the problem, support sended me a new Power Switch, and after ~20d since last post, the problem in now fixed.
As I opened the printer to replace the printer, I looked at the thermistor too, this one is ok.
Happy that the issue was not coming from an overheating problem.
