About the General Discussions category
In this section, you can discuss anything related to the Bambu Lab P1P 3D Printer.
Hello
recently the p1p has been printing badly
even in the slicer it takes longer to print than you are used to.
I’ve tried everything, factory reset, older bambulab studio version.
also new SD cards.
it is always the same, with every pressure.
it prints something, falters, then prints again, stops again
greetings
why did my P1S not work when i got it delivered? Motor b abdnormal issues
hey guys im new ok so a lasy night got this erros message 0300 08008 and now my tool head is not heating up properly
I also have problems although i bought mine new. Oh man.
Hello, I have been experiencing layer shifts of 1mm several times in one print. I already clean the rods. Adjust the belts tension, reduce speed and nothing solves the problem. Can anyone help me?
I’m starting with a new P1P and using the SD card that is showing some ware.
Can I make an SD CARD from a regular micro SanDisk card ??
The PIP offers to format an SD card, BUT does not recognize a store bought micro SanDisk card !
How much did yours cost ?
Thanks for your time. :-))
Most cards are pre-formatted as exFAT, and many devices, like our printers, only recognize an unformatted card or one that has a FAT32 file format.
You can reformat your card as FAT32 in a computer and then transfer it to the printer. Windows will not apply FAT32 to a card larger than 32GB, but there are many utilities that will. I like Rufus, another free option is EaseUS Partition Master.
Hello friends, over the past month, my P1P has given me many problems. The cutting blades wear out very quickly and can cause jams, and on top of that, the filament cutter sensor cable broke. Additionally, the poor performance of the blade can cause the AMS to not pick up properly. It seems that the torque of the AMS motors is very limited, and with the slightest restriction in the extruder or PTFE tube, the AMS fails. I found a great solution on another forum: print the following part and add it to your extruder assembly:
printables model 306323-bambu-x1-bowden-tube-reinforcement-strain
With this part, the PTFE tube stays properly aligned so the AMS motors can extract the filament without any issues. Bambulab should work on improving these motors. That’s why I also recommend not placing the AMS directly on top of the printer; spacers should be used so that the bottom of the AMS doesn’t pinch the PTFE tube.
Hi looking for suggestions on the best place to sell my P1P
I have two - but I don’t have the box to ship in - not really used and about 1 year old. I just don’t have time to take two days to just to use it. I have to Dry filament before using and if I only have one day I just don’t have that kind of time in my life. I am in north Florida
Thanks
New P1S user here; didn’t see a ā€˜new user’ category.
Bought it used last week. ā€œItā€ is a P1S with a defective camera, AMS, Panda Touch, Panda Lux, and I think that’s it.
I came from the Creality Ender 3 (plain Ender 3) world. When I got the Bambu home, I printed a benchy. That took 3.5 hours on the Ender 3, but 30 minutes on the P1S. Woohoo!
After doing that, I decided it was time to find out why the camera wasn’t working. ~25 removed screws later, I had my answer - the ribbon cable to the camera was mangled, cut in one area and abraded down to copper in another. And, it was stuck to the left cover panel. I did not reassemble it; I don’t need it that much. And, I don’t have much desire to reassemble it only to have to disassemble it to replace the cable.
New camera (and extra screws) are on order, so the printer is unusable until then. Hopefully the new camera comes with the ribbon cable.
In everyones experience with printing PLA is it better to have the top of the P1S off/raised or the front door open?
I am trying to print 2 objects on the Same plate with different color combinations. I have figured out that if you slice by object you can do this when using the paint color option. however I would like to change colors based on the layer when slicing. the Change filament is grayed out when trying to do this. Has anyone figured out how to do this? For instance, I have 2 identical objects on the plate, i would different color combinations on both by layer height. The paint option is way to cumbersome and very hard to get exact.
Hi,
First of all, I love your product! I received my P1S yesterday and have been using it a lot today. However, I’ve encountered an issue: the wheels at the back of the printer responsible for X/Y movement are already squeaking.
After some research on the wiki, I found that I can use the 50024 lube to resolve this. I’ve already ordered it, but I think this could be an area for improvement. Perhaps you could consider including a small amount of that 50024 lubricant with the printer
Thank you for your attention!
Best regards,
GM
Hi,
We are new to 3D Printing so I’m looking for some help please. My son recently got a Bambu Lab P1S, he wants to use it to design & print parts for model tractors eg exhausts, weights, front linkage etc.
What software does he need to get to allow him to do this?
Thanks
Michelle
Hi how can post issues instead of replying?
also is there a way to check these forums on the bambu app?
See Understanding Discourse Trust Levels
TLDR version: Spend 10 minutes or more reading at least 30 posts in five topics to raise your Trust Level to Basic, which allows starting new topics and posting pictures.
And how does one start a new topic?
How do you create a new post on this forum?
