Looking for some guidance here. Been trying my luck on ABS (eSun ABS+) and it seems to be failing at the same height on every print. Did the whole tuning and importing of eSun preset process, but also tried generic ABS setting/profile.
Tried printing the Bambu refillable spool and in this case a VORON Stealth burner.
Also read the infill might be an issue so changed that to gyroid and change the reduce infill retraction.
My printer has been replaced under warranty due to sticky carbon rods, however I had the same issue on both old and new.
If I set te Auto recovery from steps loss, it will continue however the print looks like absolute poop at the failure height.
If you can save the project with the settings you used and send it to me I can take a look. I’ve been using Hatchbox ABS more lately but I have also used eSUN ABS+ to print Voron parts on my X1C.
Ok I got it. I just put a black spool of eSUN ABS+ in the dryer just in case so it’ll be tomorrow before I try it. Can you measure the max height of the piece before it failed so I have some idea where to start checking? I’m guessing at about 5mm.
When you printed with the textured plate did you have flow calibration on or off?
I’ve noticed I can print fewer quantities of small parts in ASA without issue, but as I up the quantity on the build plate, the issues occur.
Maybe with larger parts- or multiples, there is too much cooling occurring between layers? Once the print gets farther away from the bed its enough cooling to cause failures??
