ABS always failing at same height
So added the pre-heat G-Code from this LINK and had the chamber warm up and settle, tried the voron cube with standard settings, but also the slower one that Bambu Support gave me, no luck…
Tried using Bambu Labs branded ABS, this should work, one might hope.
If I had known ABS was not an option, I’d probably would have bought the P1
