I just wanted to ask if this setting is new on the P1S settings screen with the new firmware. The reason I ask is that I changed to a 0.2mm nozzle last week, and I don’t remember seeing a place here where I should have changed it. Nozzle is the only thing in the menu under Accessories.
Yes
Yes its new. It wasn’t an option before the latest update. I looked for this a few weeks back when I switched nozzles but it wasn’t an option on the P series only the X series.
Glad to see they have added it.
Yes, it’s new. It allows the slicer to bring up a warning if you try to print certain filaments with a stainless nozzle when you should really be using a hardened nozzle (due to extra wear). Also it will warn if you try to print with a different nozzle size than what you’ve selected in the printer menu.
