Add Pause in drop down greyed out
Any suggestions as to why the ‘Add Pause’ line is greyed out in the menu when I right click on the RH slider in the preview tab? I’m using Orca slicer, and trying to pause the print to change filament colour for the raised lettering on the top of the print.
The greyed out options are only available, if the mouse pointer is over the dots with the plus sign. At your screenshot, select “Jump to layer” and after this, you should be able to select “Add Pause” at this layer.
Thanks for your reply. I did have the mouse pointer on the dot with the plus sign but I had to move it to frame the screenshot.
I just tried it again - right click on plus sign, left click on jump to layer, select layer, then right click on plus sign again. Still greyed out unfortunately.
I’ve tested it with Orca Slicer and it works like expected. Can you create a new Orca Slicer Window, create an object (e.g. Benchy), slice it and check again.
Yes, I did that, same result though. I’m using a Mac, do you think that would make a difference?
I’m using Mac too. :slight_smile:
I think you might have to drag the right “thermometer” layer selector to the desired layer and then the other items may become available, they don’t make sense at 100% when the print is already done.
It seems to me that it depends how many plates are in use. I just closed the open project and opened a new one with only one plate occupied and all four menu items are now available. Happy days.
Thanks all.
March 24
I just had the same problem again and noticed I had the slicer set to Global. Changed to Objects and Pause became available. I suspect this was my problem all along.
We all live and learn … Thanks to all that helped.
Also make sure you have it set to printing by layer and not print by object that was my issue
Yes, that’s what it was.
Thanks for your response.
It should be possible to use this pause function even when printing “by object”…
This too was my problem. But I also agree with @GranMathias - pausing should also by possible for By Object prints.
If you go under “Global” settings, scroll down a bit and find “Special Mode”. Under Special Mode you will find a setting labeled “Print Sequence”, this setting needs to be set to “By Layer”.
Print by Object! This was my problem; you’re King!
I don’t think the currently marked “Solution” of changing from Global to Objects was correct.
Printing by Layer did the trick for me and now I can add pause.
By the end of 2025, that problem still remains unresolved.
Change to Print by Layer, it won’t work with Objects because it can’t tell which object it needs to pause on.
Given that the layer slider is cumulative for each additional object it shouldn’t matter. For example, if I have a model that has 10 layers and I copy/paste a second copy of the same model with the plate set to print “by object”, the layer slider will have 20 layers. 10 for the first object and 10 more for the second. So, if I tell it to stop on layer 15 that would be the middle of the second object. I don’t understand why the option would be greyed out since all it has to do is add the pause gcode to a specified point. It’s able to render the second object half printed, and it even shows the gcode at that specific point if you use the horizontal slider, but somehow it can’t figure out to insert a pause at that point. Strange. Anyway, it definitely works that way, but I question if there is any good reason for it to work that way. Seems like a bug.
how not? in the next “layer” it starts the next object. why cant it pause before you print the next object? i want to print multiple objects if the first one is right but i dont want to have to start the whole process over. why cant it print one, pause then let me decide if i want it to finish?
This worked for me. Click the Customize Current Plate icon right next to your plate image ( orange gear/nut), change Print Sequence setting to By layer.
