It would be nice that when the filament runs out you could select the next spool it should use at that point in case you forgot to configure the automatic system. Maybe a dialog like
“Filament ran out. Please select a new slot to continue printing or replace the spool and try again”
Would be a nice feature. Maybe limit the selection to slots with the same material as the one that ran out. Would prevent printing ASA at PLA temps for example.
This feature is highly appreciated for my opinion. I was wandering why it’s not working out of the box.
100% agree this is a no brainer. Just got hit by this myself.
And let us ignore the Color if the Material is the same … sometimes i dont care about the Color if i can stich a print together with the rest of the filament laying around
The work around seems to be if you manually input/override the color the ams should auto switch without issue.
Not if you load a Bambu Spool with the RFID Tag.
That maybe works with other Brand Spools or Spools without Tag.
But it really would be a big Improvement to have these Options
I thought the AMS automatically switches to another spool of the same material and color?
It’s there, it’s just hard to find: Auto switch filament doesn't work - #30 by just4memike
However, the AMS has still hugh potential, my actual wish list:
At Slicer / Prepair / Filament: A Check box to set a slot passive. e.g. only work with slot 3 and 4.
Also a definition of a reserve slot, e.g. slot 8 as a reserve for slot 7 as well in Slicer / Prepair / Filament.
When sending print jobs to the printer, not only a display of “A1” and “it`s color”, may the material type in AMS as well and may de…
assignment of multiple colours when printing again (X1C display will adjust the data sent back to slot 1 doesn’t matter how the datas was sent).
However, I can see that the solution is not easy and that implementation will certainly take some time - since it afects the printer, the slicer as well as the AMS as well. However, I think ones they will make something simular happen. The AMS is still a hugh potential - and is probably the reason why none of the competitors (from my point of view) can keep up. I used Bambulab because they also work on there models and don’t constantly come up with a new machine every month. That builds a high level of trust and saves a lot of my money as well… thank you I highly appreciate that.
Of course, it would be really nice to use the higher numbered slots as a reserve for materials that are seldom needed or as a storage for a slot which goes for a short time under high stress. It would be really nice to be able to access only those high numbered slots via the slicer in case some unusual printouts pop up, to go back to normal operation once the special work is done… What they implement will keep them on the top for a long time. Think the hidden treasures of the machine are only now slowly coming to light. By the way, today in a 1 hour personal discussion (face to face) with a P1S owner who had to realize that there is a difference to the X1 Carbon…
I literally bought an ams thinking this was already a thing. I couldn’t care less about multicolor prints, but this yeah it’s crazy that after a year of this thread a feature to alleviate this hasn’t been implemented. Got all 4 slots loaded with the same filament type and color. What a waste
Definitely. I just ran out of white pla. however, I do not care about the color; all the other 3 slots also have basic pla. Why can’t I choose one to continue the print? this is bothersome.
If you aren’t using bambu filament then you can remap another color as white and it should automatically use that other slot.
I tried this but it did not work. I did it when I ran out not before.
If it has the same type of filament and color and the “backup” filament is toggled on, it should work.
Allow AMS filament editing/recognition during active prints and run-out pauses
Problem
- The Issue: Mid-print on my P1S, I added a new spool of the same color to a previously empty AMS slot. The printer locked all filament editing for the entire job, including during the run-out pause when the active slot finally went dry.
- The Result: I was forced to wait for the entire print to finish before the new spool could be recognized or assigned, completely stalling the print.
Request
- Dynamic AMS Editing: Allow users to edit AMS filament settings (type, brand, and color) at any time, including during an active print and at a filament run-out pause.
Why It Matters
- Seamless Spool Swaps: Same-color swaps are incredibly common for large prints. The current lockout behavior forces unnecessary downtime and requires users to babysit the printer.
- Improved Workflow: Allowing mid-print edits would make the AMS truly seamless, letting users pre-load backup spools on the fly without interrupting the print queue.
Thanks for considering this!
100% this needs to be added. Such a strange quirk that you can’t tell it during printing so you have to wait. Okay if its about to run out of the reel during the day but 3am is a different story.
they thought about this but allowing htis will make any fillament owrk isntead of bambu lab ones, and I dont think they want that.
There is no restriction on using 3rd party filament.
Honestly seems like a no brainer. Example - all the spools are the same “TYPE” (PLA). We should be able to utilize all four slots as we please within the context of our model choices. “COLOR” should absolutely NOT be a variable within the holdup of implementation.
