Alternative Lubricant Grease from local supplier in South Africa
Good day folks,
Can you advise if this product is safe to use on my P2S?
The CRC White Lithium Grease 500 ml (30515-AD) is a high-purity, NLGI Grade 2 lithium-based aerosol lubricant designed for long-lasting, high-adhesion metal-to-metal lubrication.
This is the only item I can find from Amazon (locally in South Africa). These are only for US markets and to import this is extremely expensive and will take a long time to reach is.
Equivalent Alternatives
For users in regions where the above products are not available:
(Ensure that any alternative meets similar viscosity and temperature-resistance standards.)
I would NOT recommend white lithium grease. But here is what Bambu wiki has to say: Bambu Wiki
The nearest thing to what Bambu Labs supplies in their tiny tubes would be Super Lube 92003, Silicone Lubricating grease. And that is only for the screws.
For the sliding rails, use Super Lube Silicone Oil. Both should be available through Amazon, or possibly a local Auto Supply, or Harbor Freight if they exist in South Africa.
But, to my knowledge, the Super Lube silicone lubes are the right stuff for our printers. Or maybe you could order Bambu Labs lubricants, like what comes with a new printer in the tool kit. Use sparingly, a tiny amount goes a long way. Too much goes everywhere. :nauseated_face: :poop:
Don’t use aerosol cans for lubing your printers, either. Beside just being very expensive for less actual grease, it does lead to grease spattering everywhere and can cause issues down the road.
