I currently have a 34 hour print of a figure with 6 colors. When the AMS feeds the filament to the extruder it always stops. He makes it to just after the hub unit in the AMS (you can see the filament at the back) and then suddenly all the lamps on the feeder units stop lighting and somehow restart. I can’t find anything about it on the internet. Has anyone else had a problem like this?
There is no filament stuck anywhere.
Video of the Problem:
The problem occurs with all spool holders. No matter what brand
I’ve already written a support ticket but from what I’ve heard so far it may take some time. That’s why I wanted to try it here in parallel. I would like to thank you in advance for all the helpful comments!
Okay, apparently this must be a problem with the first stage feeder? When I load filament on the slot, all the LEDs in the other slots always go off and then turn on again one after the other. If I fill another slot with filament, this doesn’t happen. How is that possible?
I’ve no idea about the ams, but it sounds/looks like the motor drives the filament, then comes up against a jam of some sort. It then draws extra current, which either drains the power to the leds, or software detects it and does a reset. There’s obviousl;y gearing in the drive system, I’d take it apart and have a look.
Hey thanks for your answer. I already took it apart and cant find any jam. The other slots or stage feeder are working fine. For me it seems like a short circuit in the stage feeder, but no idea 100%
I just bought my P1S today after returning my A1, I must say I am already preferring the A1 AMS Light compared to this, I have a similar problem upon setup, that the spool feeds in and out about 3 times then attempts to feed further and just wears a grove into the filament before retracting again, and again and again rinse and repeat.
I had a similar issues once but not all lights on the AMS were flashing like yours.
A roll that wasn’t used for a while refused to go all the way to the extruder.
Sometimes it made it to the inside of the printer at other times not even out of the AMS.
Checked all tubes checked the gears and other things in those tiny motor boxes but could not find anything wrong.
I used a spare length of ABS and it went through all the tubes just fine.
Put all back together and voila! The filament still got stuck randomly and never made it to the extruder.
Long story short:
The filament was pushed back and forth many times and it was quite rough.
I cut that entire part off.
Upon checking it closer I found a spot of about 2cm in length were the filament looked bulged, not really round…
Don’t know if this was the initial cause of the problem or the result of being mangled so many times but with all the rough cut off it went through again.
It failed again toward the end of the roll where it started snapping off …
I recently encounter transport issues again.
No obvious causes, filament looking fine.
One of the teflon tubes in the AMS was worn out but only is one areas lengthwise, causing a lot of friction if the filament ended up in this ‘slot’.
Only found out after trying to push some cotton through to check if any debris is stuck inside - it got notably harder to push in this damaged area.
Wasn’t visible by trying to look through it…
I’m experiencing a similar issue with the AMS on my X1 Carbon. It seems that the filament selector lever is not activating to release the filament toward the extruder. As a result, the system keeps trying to push the filament through the feeders, but when it reaches the selector (hub), it gets stuck and continues applying force.
Since the filament doesn’t go past that point, when I pull it out manually, I find a worn-out section, likely caused by the feeder gears grinding in the same spot repeatedly.
I’ve already opened and cleaned both the hub and the encoder, but the issue still persists. I suspect there might be a sensor inside the hub that is not detecting the filament’s presence properly — although I couldn’t locate it.
In the video above, the filament comes out a bit through the PTFE tube, but in my case, it doesn’t even get that far — it gets stuck before that point.
Has anyone encountered a similar issue?
Any advice or insights would be greatly appreciated!
Sliding how? It’s quite stiff… I can activate it manually, but it requires a lot of force. Do u have any video showing how it’s supposed to behave? Tks
The black part that slides over the left nozzle should move freely up and down when the nozzle is not installed. Follow the guide to remove it and inspect the mechanism for any debris or obstruction.
I didn’t quite understand — which black part exactly slides over the left nozzle? Could you please clarify that for me? Thanks in advance for your help!
I am having a similar problem, maybe slightly different.
When I attempt to load from any of the 4 slots from my AMS(1)…the filament only travels about 3 inches into the Front Feeder Unit. I can hear the motors spinning, and I can see that the Front Feeder Unit is trying to push the filament through to the Internal Hub Unit, but the filament does not move any further than about 3 inches.
This is happening on all 4 slots, and it just started 2 days ago.
I feel that it is highly unlikely that all 4 Front Feeder Units have gone bad at the same time.
I took the AMS unit apart and tested for plugged areas, but the filament can manually be pushed through the AMS to the Internal Hub Unit…and If I press the springed plunger I can push filament straight out of the back of the unit…from all 4 slots.
I have a 2nd P1S with an AMS(1) and this is not happening.
I am on firmware:
Printer: 01.08.02.00
AMS (1): 00.01.06.62
AMS Hub: 00.00.00.43
Not sure if you are still having this issue but I just ran into the same thing last night. Turns out one of the magnets in the AMS hub got turned somehow and needed to be flipped back into position. Not a terribly fun process since all the magnets and springs want to fly out of the housing.
There’s a wiki on this. Just search: Remove and install magnets in AMS filaments hub
You can use these instructions to find and reset the flipped magnet.
