AMS fails to load filament
I have some similar topics to my issue but nothing exactly like it. My AMS fails to load all filaments, with the following error: “Failed to extrude the filament. Please check if the extruder is clogged. After troubleshooting click the retry button [0700 8007 113229]”. However, I can load and print from a non-AMS spool with no issues. I have also confirmed that the filament makes it all the way to the extruder when loading. It just seems to fail to latch somehow. It basically hits the extruder and almost immediately backs out.
Anyone have similar problem, or better yet anyone find a solution?
I am having the same issue.
Try cut the filament end on 45* before loading in the AMS and try again
Check if the PTFE tube is installed well and relatively good angle to the extruder the path inside may be not well organized
If that does not work there are some prints for Bambu to solve this
I personally have not experienced this issue, but seen somewhere people complaining and printing the improved part like:
https://www.printables.com/model/418693-ptfe-guide-extruder-bambu-x1-carbon-no-collision
or
https://www.printables.com/model/338073-bambu-x1-ptfe-extruder-bracket-ams-error-fix
I have a support ticket open and have sent over a bunch of video and logs to them. I will let you know what the result is.
If it were me, I would open the extruder and look for a small piece of filament jammed into the knurled wheels. Or next to them. Ive seen where it would still work with the external spool because of less force needed vs coming all the way from the ams. And feeding by hand, you may just be applying enough force to push past it. How do the prints look when printed from the external spool?
I got same problem and it drive me nut. Let me know if you got answer from bambu
As @StreetSports says, I’d take the extruder apart. It’s not that difficult after you watch the video on the wiki. Check that the black knurled wheels are clean. I had a heat-creep induced clog and there was some soft filament rest in parts of these wheels. Used a needle to pry them out.
Mine was a faulty AMS Buffer. Bambu Tech support was great I had to perform some actions and ship over logs a couple of times, but they diagnosed the issue and sent me a new buffer.
Hello,
what do you mean by AMS Buffer please ? is it this part https://eu.store.bambulab.com/en-fr/collections/accessories-for-x1-series/products/ams-active-support-shaft-assembly
or this one : https://eu.store.bambulab.com/en-fr/collections/accessories-for-x1-series/products/ams-driven-support-shaft-assembly
Neither. Filament Buffer | Bambu Lab Global
I have the same problem. Also got A support ticket and they sent me A new buffer as well. But it didn’t solve the problem for me.
I have identical issue.
If I feed filament myself, and print with it all works fine, but if it needs to feed from AMS, even though filament detector in extruder detects it, it spools it back and says failed to extrude.
I am struggling to load filament, I found a blockage in the PTFE tube at the back of the printer, however having cleared it and cut the filament at 45 degrees, it still doesn’t load the filament, its frustrating because I cannot push the filament all the way in, it stops and is unloaded by the printer over and over, meanwhile it keeps instructing me to load filament.
I now too have the same problem. It’s not the extruder since it feeds the other three colours. If I hand feed the filament it works, if I leave lots of slack on the spool it works. Only when it needs to pull the filament from the spool on the AMS does it fail. The specific location is Spool spot #1. I have tried three different filaments as well. It also retracts with no problem.
I think I fixed my own problem. I took out and reinstalled all of the PTFE tubes and that seemed to fix it.
In reality, I’m Canadian and I’m trying to print a Donald Trump Duck. I refuse to become the 51st state. The government is watching and thus my electronics problems. Think I watched the movie Snoden too many times. LOL!!!
I received and replaced the HUB, I haven’t tried it yet, since I’ve been printing by manually inserting filament through the back of the printer.
I checked all the tubes and settings. Couldnt figure it out. got that weird error.
The worst is that the filament would then backtrack faster than my rollers and loosen a perfectly good tight roll. ugh.
so i’d hand tighten and try again.
I tried to add a little tension to the spool, manually, and as it ‘tested’ that the spool was tight, it started heating the bed/calibration and would print fine.
When i multicolor i have to put a little pressure in the spool and boom, it bypasses the test and prints fine. but god, doing this on a print with a few changes… isnt bad. Doing it on a bigger issue. OMG… nightmare.
It happened after the 1.08 firmware update. I backtracked the filament to the 1.07.05 but didnt fix it. The AMS firmware didnt backtrack from what I can tell.
Is it possibly a AMS firmware issue?
I have 2 AMS and 2 X1C.
I have one in the school library and one in my room.
Swapped the AMS and the error followed the AMS.
Cleaned both and checked the tubes. everything hardware looks the same on both.
the software on my AMS was upgraded during the 1.08. but i dont thing the downgrade to 1.07.5 altered the AMS firmware.
It happened after the 1.08 firmware upgrade
I should have updated this. I disconnected the tubes and reinserted them. Problem solved!!!
I’m having the same issue. I need to fix it, working on a project.
