AMS function out of order!
In the last few days, and I think after the last updates, my printer (P1P) has stopped printing from AMS. It starts the printing process but stops at the moment it should feed the filament. And it stays there. And it remains dead. It cannot start printing. When I put filament in the back (outside AMS) it works normally. I also tried AMS on another printer and it works normally. Today I talked to a friend of mine and he described exactly the same problem to me. The only thing I haven’t tried yet is replacing the HUB. (I tried with another sd card too)
This can sometimes occur when the cabling gets dislodged.
If the cables are all in correctly, you should get white LEDs.
If the cables are partially in, you will get red LEDs and they flash.
If there are no LEDs, the cables are disconnected.
Whatever you are getting, turn the printer off, unplug all the data cables, wait for a couple of minutes, plug in the data cables again. Then turn the printer on again and see if the situation changes.
I made a downgrade and all fixed!
