Are the magnets and springs for the AMS internal hub available separately?
I ask because I nearly lost two of them today while fixing my AMS due to a filament jam that caused one of the magnets to get flipped up from it’s slot inside the hub. Disassembling the internal hub is tricky and that’s how two of the magnets got lost, temporarily.
The magnets are a wear item if you run abrasive filament. They can actually get grooves worn in them if you’re running harsh filament. It seems a bit excessive (and wasteful) to have to buy a whole other internal hub as a replacement assembly instead of just four magnets and springs.
I realize the reassembly job is not easy and most folks would probably be fine with just swapping out the whole internal hub. But for those that have the skills, it’d be nice to be able to get just the magnets and springs.
