Hello. Im trying to turn one of my ams lite into a system like the OG ams. I would like to retain the rfid since I only use bambu filament. To retain that I would need feeder wire extensions. Does anyone know what connector they are and if so where to get extensions?
A quick search here finds many similar threads, here is one.
Thanks for the info. i will go look now.
ok so thats for the ams to printer. im looking for the ams feeders to the ams main board.
https://www.aliexpress.us/item/3256807412098367.html?gatewayAdapt=glo2usa4itemAdapt
Edit: I think I know what you mean now that I think of it but here is a mount that requires no extra cables except maybe the ones I linked to above.
I think you nailed it, at least far closer than I was!
I see what you were talking about now. I was thinking that might have been what you were after. I don’t know of any longer pre-made cables but those would be easy enough to modify by cutting ONE AT A TIME, in the center and add 2 feet or 3 feet or whatever you need of the same stranded copper AWG wire. Don’t use that CCA (copper clad aluminum) stuff.Put heat shrink tubing on the wires and solder the two ends and finish up with the heat shrink. Doing them one at a time will guarantee no mistakes on swapping the wires by accident.
Thanks. Looking around atm for what the connector name is. I want to be able to put together a parts list for this so I can be a big project that many people can build. Extending wires manually isn’t something everyone wants to do nor can do. I want to make it as simple as buying all hardware and printed parts.
I may end up doing what you said as a start. Thanks.
I don’t even see that Bambu Labs even sells a spare cable like the one you want longer. I was going to suggest you buy one of those to make it easier to practice modding one or to send it off to a place that could make them for you. I even looked at the main board they plug into and without actually taking one apart I am not even sure if both cables are the same on the ends but I assume they are. Good luck.
Edit: Just looked at the WIKI and those look like some more complicated cables to make than I originally thought. Looks like a tough problem to solve if you ask me.
Hi @Voltage , is there any chance tht you know what type of cables are these exactly? I bought a AMS lite at a craiglist and these cables are missing in a left part (1 and 2). I dont know why but I finded that out during trouble shooting. Whole left part doesnt worked.
Hi, unfortunately I never pursued the matter as I was not the original thread starter and was not planning to do what he was trying to achieve. The cables looked more complex to make than originally thought. I would contact Bambu Labs and see if they can sell you some or look for a used or even broken unit on ebay and use it for parts.
Edit: Check this out:
Yeah I tried to contact support but SN is missing on my device, I couldn’t find it anywhere, also with help, but it’s missing so I cannot submit a ticket. I thought about making my own one but after spending a too much time with calipers and still didnt find corect connectors. A type of conector and pin layout would be ground breaking for me. So if you find something I’ll never forget to you
To find the SN for your AMS Lite:
In Bambu Studio select the device tab
Then click on Update
The serial number for both the printer and the AMS lite are listed on this screen. The AMS Lite needs to be plugged into the printer for this to work.
Thanks a lot man, but it doesnt changed anything. If inner cables are missing I have to buy a whole new unit. Even if its working properly. I tried to swap motors between left and right and they are working properly. So poor me, for just a 10 inch cable that cost I thing not more than 10€ I will have to buy whole unit for around 70€.
