Check this.
Yes, I found a solution. The object color in bambu studio has to be the same as the printer color, so the purge volumes are applied correctly. Now, I set the colors in the printer, sync in bambustudio and set each color to the corresponding color.
al final con que valores de purga te quedo la configuracion para resolver ese problema? me pasa lo mismo de rojo a blanco
que valores dejaste en los volumens de purga bro? tengo el mismo problema
