AMS Sync and Bambu studio
Hello… I think that Bambu Studio’s programmer should make more efforts to solve the problem of sync between the slicer and the printers.
I own an X1C and a A1mini, both connected to AMS and AMS-Lite.
Everytime I switch printer it’s a real pain! Almost never synced with filaments inside the AMSs in the Prepare and preview page. In the “Device” tab i can get some better result but not satisfying. It seems to “forget” some filament, it doesn’t know anymore what it was in before, even if filaments are Bambu spools with RFID inside, randomly…
Obviously a big sequence of errors (any compatible filaments or something similar…) when trying to sync (or re-sync) …
Is bambulab aware of these difficulties ? I don’t really think to be the first…
If you go to the device tab I hear a clunk as Studio talks to the printer. If I then go to the filament table, I can click on each spot and it will prompt me with what’s in the AMS to make the filament table agree with what’s in the printer. At least it worked last time I tried it.
But if you change filament during a print, the AMS doesn’t read the RFID tag and just assumes you replaced a spool with the same filament. If you changed colors or even type during a print, I’m pretty sure it will not be aware of the new filament until you pull the filament tail out of the AMS and put it back so it can then read the RFID on the spool.
Other than those, not sure.
I know all that. Tried a lot …
I’ve never inserted a new filament during any print… And as I say, what is illogical, is that the spools are from Bambu, they have NFC and when I insert one of them in the Ams it is correctly read. But after switching (Randomly) … It appears white with a question mark. The filament is forgotten🙁
And the sync method is anyway not good .
It would be better if, switching printer, I obtain their filaments in use directly without manipulations of any sort…
What would cause AMS to lose track of currently printing filament?
Started a print in studio with PETG HF Green, viewed print in Handy, showed PETG Green, a few hours later during the print, that slot was blank. Had white dot with ? Mark. Print finished fine
Exactly… I think this happen to lot of users :slightly_frowning_face:
I would agree with the OP. I own 3 Bambulab printers (A1, A1 Mini and X1C). Two of them have AMS’s attached to them and if I want to start a print on another printer I first have to go to device and select the printer there and then go to the main screen and select the profile. Then Sync or resync every time.
Thats just annoying. What I actually would want is a seperate window per printer.
I wonder if the troubleshooting team read us…
It would be nice to have a little feedback or at least the confirmation that they know the issues …
Probably they don’t read us at all… :roll_eyes:
This is a regressive bug.
It was fixed a few versions back, then it reappeared.
It is really annoying.
People keep saying “use sync”, sorry, it doesn’t fix the problem.
If you are swapping between multiple printers. The filament drop down is never populated.
The only fix (read “annoying around”) is to toggle between your printers multiple times times.
If you have an X1C f and A1 mini and you were in the X1C and now swapped to the A1 mini, then…
  • Toggle back to the X1C
  • Toggle to A1 mini
You should now have the drop down choice of the filaments in that printer’s AMS.
If not, repeat the toggle above again.
I have a few printers and spend a lot of time doing this stupid shuffle. I had a few glorious weeks where it worked before an updated studio regressed the issue.
As to BL fixing it, who knows. Do they read here, unlikely.
If you change the category to a bug report (use the pencil in the post subject area and enter an optional tag of feature-request (whatever the closest match for you chosen main category is) then they do look at those occasionally.
This “occasionally” reassured me a lot :rofl:
You are right there are issues claimed as solved and then reappearing as well as issues claimed as solved but not solved at all…(For exemple: the “repair model” was available only for windows and i own a mac… they said updated and running for mac too now but as soon as I tried, the window popped saying “windows only” … )
I think there is a bit of confusion between the development team members.
The Mac option only went to a web service unrelated to BL, annoying that they have the code for the Windows version, but, not the Mac.
It makes me think they have a third-party library to provide the Windows repair feature version that they don’t own and didn’t write.
The Windows mesh repair function is a standard part of Windows, along with 3D Builder (a simple modeling program), a 3D viewer, and 3D support in Microsoft Office. Bambu Is simply accessing the mesh repair function through the Windows API.
If mesh repair were not a standard part of Windows, I doubt that Studio for Windows could repair a mesh…
It is third-party to BS, as I said, I doubted they wrote it.
A big reality as bambulab doesn’t have a programmer to implement some geometric function using standard APIs? I thought it were building nice printers tho… :rofl: :rofl: :rofl:
The Bambu Studio bug with to printer or more about reading filament data from printer is ridiculous.
I´m playing pingpong too between printers until it detects the correct filament data.
The same issue happens to me. Using 2x P1S Printers.
No Reliable Sync is performed when switching. Sometimes it even syncs the right colors but sets all the Filament Types to “Bambu ABS” for no reason.
Sometimes it says “no compatible AMS Filaments”. Playing a lot of Ping pong helps in some cases. Others need a full Restart.
Any new insights into a Fix?
I just got notificated about the new bambulab studio version.
in the “BUG FIXED” section they say:
  1. Fixed synchronization problems with the AMS in certain cases. (#5181, #4863, #4949)
I download and installed the new version and I tried soon: I got “no compatible AMS filaments” just like you …
At least they seem aware of the problem. But I still would prefer a simple change-printer-and-ams-filaments all in a single operation instead of click on device, change it, go back to the slicer, resync and so on… :confused:
They should do, I constantly moan about it.
It was fixed in one version of the build and the next version regressed to the issue.
Very annoying.
Yes, I take it personally!
I promise you I am (mostly) sane.
even too much…
The management of AMS by the studio app isn’t good at all.
I am also occuring in a one more issue…
I used an external filament and now on my printers there is always, constantly a 5th filament as if it was a 5 slot of AMS (and obviously the filament is retired from the external source…).
I delete the 5th filament and it returns on every resync…
what a mess ! :sweat_smile:
Me too i promise you… I “was” mostly sane
You can manually go into the BS device tab, edit the 5th wheel filament and reset it.
It will remove everything for the external entry until you set it again next time you require it.
I just tried the new BS version from today. Using the drop downs from the filament chooser (top left of the prepare tab in BS) the correct AMS entries appear in the drop down when I swap between the many printers I have.
Fingers crossed this isn’t a one-day wonder.
