AneoPsy, the fastest man alive
sooo… here is our favorite guy I just saw that he actually has 2 accounts now. those models where taken down on his other account and now he is putting them on his new account or 2nd account … we are aloud to have multiple accounts now ??
https://makerworld.com/en/u/2253346376
here is the link
The prophecy has come true. :rofl:
You should start by learning to read the guidelines, nothing stop from having multiple account, lot of people do it for professional purpose where you have printer in shop and printer at home.
i did read the guidelines dude. the problem is that people will get ban and just create other accounts. bambu could stop this from happening by detecting either the ip adress or the serial number of the printers. whats the point in having rules and getting banned if you can just make another account and cheat the system again! you dont need to read the rules to understand that what your are saying is totally absurd and doesnt need a high IQ level to understand that it shouldnt be aloud. you also can have the same printers on the same account one at home and ones at your shop can all be in same account.
Personally, like other people I know, I use 2 accounts, one for my personal printer at home and another that is SHARED through the company members for professional use. It’s pretty easy to see why having multi accounts is important.
First, in a company, you’re not the only one using the printer and/or the account associated with the printer, so sharing your personal account is not the smartest idea.
Second, in a company, if each member wants to use their account, it’s not easy to do so because BBL printers don’t handle multiple accounts, and if a member has to disconnect the previous account to log in with their account, it would be the worst user experience.
That totally normal to find multi-account experience in professional domain, but your high QI cannot understand that.
You are confusing 2 different things. If MW want to ban an account or someone, they can already ban the IP and this is not related to multi-account usage.
Here, in this case, aneopsy was not banned, so his second account is completely different from what you say.
This isn’t a situation where someone is just creating a second account to separate their work life from their professional life. If AneoPsy did indeed create a second account like that, it’s probably to get around the weekly point redemption caps. If his goals are to farm points, and them preassembly sell what he buys with the gift cards? His main account is obviously doing good, and I’m pretty sure he’d be hitting that weekly cap. If he felt he has the right fire to make it happen, I’m sure he’d go for it.
How do you know that? It’s all speculation. So he created a real company named Aito3D, 1 month ago (facebook page creation date) just to get around the weekly restriction? and he did it only 1 month later?
I don’t think so, especially if his main account has 1.2k followers, he would gain way more points by posting on the main account vs the secondary account.
You can only redeem so many points a week though, and with the numbers on his designs, he’s very likely hitting that weekly limit. You can’t transfer points to another account. So for him to get around that, to farm more points through his system/approach, so he can redeem more gift cards, he’d have to setup another account.
While AneoPsy isn’t technically doing anything wrong, it’s obvious that his approach is in a moral gray area that does understandably bother a number of people. He started out by farming print profiles that were manipulated in a way to be misleading, to try and trick people into using his print profiles. I mean for freakin’ on’ a weekin’s sake, the rules that Makerworld put in place for printer profiles directly affected him, and from my perspective those rules were made because of him and the issues and complaints it was causing. I mean, right before they were implemented, there was a bunch of discussions on here about him specifically, about all of the very things that the rules ended up changing. He’s not the only one, but it was obvious from the start he wasn’t here in good faith for the community, but was working to farm points for his own gain.
And you see that in his current profile and body of work. The style of his thumbnails were lifted from elsewhere, and everything he does is simple models that he more or less copies from others. They’re all very small and quick to print too, quick to make. Like you could probably print his whole profile on one roll of filament and still have plenty left over.
I don’t see why you’re getting so defensive over the guy. He clearly does not need defending, and he does not care at all about any of us or our opinions. I’m not making commentary on anyone’s legit needs for separate accounts either. I’m just pointing out the patterns of behavior and how that can explain things. Neither of us are him though, so your speculation is just as much speculative as my speculation.
its not speculations. I have seen his models before and probably do have screen pictures of those models or others do have them, we saw his models long time ago. its not speculations when a user removes his models to put them on another to gain and redeem more points. thank you
if this is acceptable well a lot of users will start doing the same and we will still see a lot of spams and similar models spams for no reasons. i dont think this is what makerworld need
ive got proof
psy maib
psyalt
I’m not defending him specifically, it’s just that I hate hypocrisy. Lot of users who criticize aneopsy are doing the same and accusing him because they are concurrent.
Kenny89 (KenPrint3D) spamming print profiles (also copied Aneopsy with *fast style). Publish ton of model even without picture of proof that it was printed.
sharcrypto shar3d use a secondary account, but way worse as he rated himself to make his print profile first in the list. (A print profile that has been rated will be displayed before (on top) a print profile that has not been rated.)
moonrakerone spam print profile to farm point, with 584 print profiles.
cruse2382 spam model to farm point, 394 model, half are car silhouette uploaded in batch
Here is the hypocrisy, let the fun begin.
how come im in the list
id like to see your account as well to see what you did wrong previously. also where do you see me say that i didnt do those fast models ? everyone was doing the same, if changes dont apply again a lot will still do the same as I specified earlier. I dont think this is what makerworld needs, a lot of users had to copy him before we actually could see a makerworld change before they act. should it still go this way again and all users spam as he does ? do you see me creating multiple accounts ? do you see me copying all models that are online and making small changes on them like 30 models a day or whatever ? hmm no but I could do so as well and make it happen if we are aloud I mean why not ??? is that what you think ??
and @moonrakerone dos spam but ken dos not spam them without real images
you are not defending him but it really looks like you think that what he was doing was okay. so what you are saying is that we should all create multiple accounts and copy each other by remixing models ? as you did so yourself it is acceptable now ?
and look at the first 2lines and then he accuses me of 2 accounts
yeah they were actually printed models, just used same name with sloght variation and I even did asked makerworld if it was permited back then… as he was using as i found it was unfair that he was having models more atractive names then others why shouldnt i be aloud if it was permited back then. just followed the group as others did and actually did followed the rules as pictures where there, thank you
yeah idk… i saw a pst he did claiming you did rated your own print profiles… idk what that does but i havent got any points myself by rating models… or very small amount so idk whats the big deal about that story
