Autonomously printing multiple plates
This advanced Bambu Studio feature would wait until after printed model’s plate cools down to a specific temperature, then put the hotend to the very back of its range and use the 3mf to line up the other 2 axis with the model. It would then repeatedly attack the model at 100% speed until it flies off of the plate(Front door would have to be open). From there, the next print could be started. The purge at the start could be printed over a few times. Obvious limitations would include it only working on models of a specific height and stability(fragile models or flexible models would likely stay on the plate). Could also be advanced over time by making the hotend first attack the model using the non-magnetic back and then push it away.
Plates with more than one or two objects to attack would be very unreliable, but the feature could help users print multiple plates overnight, or instantly start a print after one finishes. Fails would also likely pause the print to minimize damage, as the magnetic cover would fall off. Thoughts?
This looks like a duplicate of this thread.
Join that conversation rather that splitting focus.
I might suggest you check this thread out.
Do what Jon said. His one is even older.
