Bad Nozzle & Tramming Bed...lesson learned
So, a few days ago I noticed my first layer was looking bad.
I switched to a new nozzle & it was still bad.
OK, I’m going to have to tram the bed.
So, I start loosening the side bed screws & see that back one is loose (really loose).
Alright, that is my issue…have to re-tram.
So I re-tram the bed, not a big issue I’ve done it before.
Get everything set, put the old nozzle back in & start a print.
OK, now it’s worse then before.
Re-tram bed another 3 times…can’t get it right.
So I stop, think a minute & decide to start all over again…then I remember I used a new nozzle the first time.
I install new nozzle & re-tram the bed.
I print a first layer print & it comes out good, a little close but good.
So, for the hell of it I put the old nozzle back in & re-print the first layer print.
I stop it halfway through because it’s bad.
Alright nozzle is the issue.
So, this whole process was a bad nozzle…but because the back bed screw was loose it set me down another path.
Actually, the real problem is here:
Pelo menos você conseguiu arrumar, no meu caso, é a minha impressora, e estava ouvindo um barulho de algo raspando, o bico raspa em todas as peças, algumas descola da mesa, aí descobri que não é normal… e agora estou sofrendo para conseguir arrumar e calibrar de forma que não acerte mais as peças e que as primeiras e todas as outras fiquem boas…
Try a different infill. Try crosshatch, gyroid, one that doesn’t cross itself.
well i was at a loss, tried tramming didnt work, tried lubricating didnt work, tightened four little screws in behind hot end didnt work, changed nfill to gyroid and low and behold it worked, like wtf ?
Then that seems like whatever infill you were using was hitting the nozzle…Gyroid will not do that.
