Bambu Firmware Bug Reporting Thread
1.08.50.18 not .188
typo aside also reporting same issue on my X1C with that beta firmware.
Problem: Cooling fan behavior does not match G-code or preview — turns off too early on overhangs
Firmware Version: 01.04.00.00
Printer: Bambu Lab A1 mini
Steps to reproduce:
  1. Slice a PETG model with OrcaSlicer 2.3 or Bambu Studio 2.0.2.57
  2. Enable 100% fan for overhangs in slicer settings
  3. Optionally enable/disable ā€œstart fan earlyā€ setting and re-slice
  4. Begin printing and observe fan behavior during overhang sections
  5. Notice that the fan either:
  • turns off too early (before or at the start of an overhang), or
  • turns on briefly but immediately reverts to previous speed,
  • or never activates on overhangs as expected
Other information:
  • Behavior reproduced with PETG and default slicer profiles
  • Issue affects narrow overhangs more noticeably
  • May also affect bridge cooling — observed early fan shutdown
  • Likely not limited to A1 mini and may affect other models
Related thread: Main discussion thread here
Problem: After installing new Firmware, the toolhead started grinding against the frame corners. Restoring firmware to GA, resolved.
Firmware Version: 01.07.50.18 BETA AMS2 Pro Firmware to 02.00.19.47
Printer: Bambu Lab P1S
Steps to reproduce:
  1. Installed new Firmware
  2. During my second print post firmware upgrade, the described issue happened
  3. Restored back to GA release, the issue has not returned.
Other information:
During my second print after the Beta install, the toolhead went to the front left corner and started grinding, trying to continue in that directly beyond the frame. It then moved to the front right corner and tried to do the same thing. After it moved to the corner, it dropped the plate 3 inches and started feeding filament through well above the current print.
It’s actually not a bug but for now a ā€œfeatureā€ā€¦ You cannot dry unless you remove any PLA filament from the feeder. AMS2 can only dry with the PLA filament removed from the feeder and attached to the spool. Bambu explains in the wiki that it may soften the PLA filament in the feeder which will cause clog at next print.
Thank you, that makes sense. I’ll edit my post to disregard.
Bambu X1C firmware 01.08.50.20 Beta for 110V is limiting us from raising temp to 120c.
Updated multiple of my P1S to firmware version 01.08.00.00 and AMS-1 version 00.01.06.62
Bambu Connect version 1.2.1-beta.5 encounters ā€œFailed to get AMS mapping tableā€ error on every attempted print job to the updated printers.
File is being sliced with current version of Bambu Studio 2.0.3.54
External spools error when attempting flow calibrations from Bambu Studio, ā€œinvalid tray_id or use_AMS flagā€ yet models with flow calibration selected/included do print. Also, my original AMS takes the Flow Calibration codes, but no plastic is extruded. Models with ā€œFlow Calibrationā€ checked/selected do print, however. My second AMS, slightly newer than the original AMS, prints the flow calibrations without issue.
My upgrade path was:
X1 Carbon: 01.08.02.00 → 01.09.00.00
AMS Hub 00K09A440101886: 00.00.00.43
AMS 1 00600A432321701: 00.00.06.44 → 00.01.06.62
AMS 2 00600A291105940: 00.00.06.44 → 00.01.06.62
Ok, I have the same problem. Bambu X1C, less than two months old. Printed some 250 hours so far. Everything going well.
Updated firmware to 1.09
Did a few prints.
Then I got this ā€œFailed to get AMS mapping tableā€ error.
Tried everything.
EVERYTHING
  • Printer reset
  • Reset to factory settings
  • Diagnostic run (came out ok)
  • Tried to print from laptop, mobile, internal memory, benchy, all the same problem.
  • With and without SD card
  • Unloaded and reloaded all filaments in the AMS
  • Reconnected the Bambu-net cables
  • Tried printing with external spool
  • Disconnected the entire AMS, did a factory reset, everything to make the printer believe that there is and has never been an AMS in its life. Still the ā€œfailed to map AMSā€ or whatever error, while trying to print from the external spool (the only thing it had, and the only thing to show up in its menu).
Did I already mention that I tried everything?
The final thing I did before giving up was to downgrade from 1.09 to the latest 1.08 version…
… and now finally the printer works again!
The weird thing is that I’m sure that I finished one or two prints in version 1.09 before this problem started.
I know, the conclusive test would be to upgrade to 1.09 again, but maybe I’d better wait until I see what support says and if more of these problems popup.
In the past, this sort of ā€œweirdā€ problem has often been corrected using ā€œRestore factory settingsā€ after a firmware update. Issues did not always appear immediately, but after a couple of prints. Used to be so common that I made restoral a standard part of my update procedure, before calibrating, before any weirdness could occur.
It’s been a while since I updated my X1C, the ā€œupdatesā€ have not offered any changes that I need or want.
Restore factory settings was one of the things I tried. To no avail.
But good to know. Maybe this restore factory settings ritual should be done before the first problem occurs.
I usually also don’t update, but I just ordered an AMS HT so I’m going to need the new firmware.
Thanks for your reply. If I’m going to try the new firmware again, I will for sure commence a factory reset right away.
Problem: While starting the print job, Printer gets black screen and becomes unresponsible.
Firmware Version: 01.08.50.xx beta to 01.09.00.1 (currently installed)
Printer: X1C with 2xAMS
Stepps to reproduce:
  1. upgrade firmware from 01.08.20 to 01.08.50.xx or any above
  2. start a print job with the actual Bambu Studio Version, or repeat a print (from SD Card)
  3. went back to 01.08.20 and the problem disappears.
other context:
Have to flip power switch off and on again. Happens randomly mostly during the preheat phase but sometimes also in stand-by. If it prints, it finishes the print correctly. Happens only with Firmware >1.08.50.xx (new UI).
Downgraded from 01.08.50 to 01.08.20 → no issues, prints totally fine
Installed 01.09.00.01 → Printer crashes again.
Problem: No Cold Pull possible.
Firmware Version: 01.09.00.1 (currently installed)
Printer: X1C with 1xAMS
  1. Try to perform an Cold Pull when Temperature is 100 C. The Extruder will not turn, when the Temperature of the Filament is under 170 C. There’s no option to override the Temperature checking.
I have the exact same issue. I don’t even have an AMS and never have.
Its a shame because until now, i have been super impressed with the X1C.
Did you manage to resolve the issue, if so how?
I just received a message from Bambu support that it is indeed a bug in the new firmware. They have a ā€œhot fixā€ available they say, I’m not sure what that is and whether that means that there is a new firmware version released. I have not had time to invest this further, I stay on the previous firmware until this thing is stabilized. It already took me many hours to troubleshoot, to endure beginners suggestions from support about how to load filament, until finally it turned out to be a bug in their firmware.
Problem: Errors not being cleared on latest firmware
Firmware Version: 01.09.01.00
Printer: Bambu Lab X1-Crabon
I got a filament feed error, asking me to clip the end of the filament. This cleared the issue but the fault did not clear from the touchscreen or from the Handy app. The error remained to the end of the print.
The error still remained even when I started a new print, there was no way
I could find to clear the error which no longer existed. I had to reboot the printer, this did not happen on the previous firmware
this happens every time any error occurs.
Same thing is happening with my X1C, along with a few other bugs. Worst firmware in the past year and half I have owned these machines.
Problem: No login account, only printers in LAN mode are displayed
Firmware Version: 01.07.00.00
Steps to reproduce:
1. In Bambu Studio, select ā€œSlice Plateā€ and then select ā€œPrint Plateā€
2. ā€œSend Print jobā€ windows displays ā€œNo login account, only printers in LAN mode are displayedā€. It also displays ā€œNot satisfied with the grouping of fillaments? Regroup and slice>ā€. Printer just sits there and does not start.
3. There is no ability to resolve the issue through this error screen.
4. Printer shows it is connected to the wifi.
Other information:
PLA generic filament is loaded. No AMS.
I noticed they now have 1.09.00.01 available, so I decided to give it a try. I didn’t change any filaments, just updated the firmware.
At the first print attempt, the printer again got stuck with this AMS mapping error. So the bug has not been fixed at all.
Hey man, it’s such a relief to see someone else is having this issue. Our business is completely halted because of this. Would you be able to explain how you downgrade? I’m not well versed in this area. I’d be willing to paypal you for the help that’s how desperate the situation is at this point!
