[Bambu Lab H3C] AMS 3H: Sealed. Engaged. Loaded
Integrated filament management, built for tool changer.
Nine spots, always ready.
Launching tomorrow.
Is that Bambu v12 engine? Since when they are making cars now?
Lol someone else already posted this exact same gif a week and half ago.
Switch and load filaments to different hotend / nozzle size ? would save having to load multipule rolls of the same colour
“tool change zero wait time” they say
(Not a mistranslation â€œăƒ„ăƒŒăƒ«äș€æ›ăźćŸ…ăĄæ™‚é–“ăŻă‚Œăƒ­â€)
See I knew it. You’re going to be able to use your other AMS units. If it wasn’t able to switch the tube that’s going to the hot ends there’d be no point of those parts moving. There’s no way bambu was going to let their Flagship printer be stuck to nine colors only
Your conclusion does not follow from the premises.
There’s a very obvious point to these parts moving - you can direct a single spool of filament to different nozzles, so if you want to do a single color print with two nozzle sizes, you don’t need two rolls of the same filament.
There is absolutely nothing here that provides evidence for compatibility with other AMS units.
My first thought was maybe the nozzles moving is a way to disengage the first stage feeder for softer TPUs. So on the 3H perhaps TPU would be more automated compared to 3P bypass holes.
Why?
That seems like a lot of extra moving parts to move one filament from one nozzle it’s already loaded into to a different nozzle. Seems like you’re adding a complicated step and moving parts to achieve nothing.
Edit. What?? you only have one nozzle in the exact size you need but you have two rolls of filament. That doesn’t seem like a great reason to add all this complexity to the machine. I can see it being somewhat useful.
You’ll need 9 external inlet ports one for each funnel if the movement here is for such purpose. We saw AMS3P having just one single external inlets for whatever functions, presumably hooking up 1st/2nd gen AMSes
 so, it’s probably the more likely that AMS3H will do the same.
It would make little sense anyway, who has 9 AMSes lying around? easier to just give older AMSes ONE inlet and let it be mapped to any nozzles
I think we should actually wait and see how it functions before lighting the pitchforks and sharpening the torches guys.
It may or may not be able to direct any one roll to any given toolhead.
It may or may not allow external feeds.
It may or may not allow older AMS units to integrate with the system.
Does anyone have any information to solidly point at any of those things being true or are we just assuming? To route any of those 9 to any of the toolheads would be a really complex track system.
Not saying it isn’t going to do this or that it is, but I do agree that moving those little input funnels does seem to imply it’s pushing them to different feedpaths. Whether that’s just 2 positions or more? Only they know so far.
If you look at prusas indx they appear to have tied colours to nozzles by a little flap underneath its riser , which does appear to go against what bambu lab have achieved with the ams , which was 4 ams and multipule colours, one hotend (automated and ready to go h2c 6)
Edit things have evolved (switcher )
The patent is somewhat dated, some details appear to differ but this is about as detailed as it currently goes.
Nothing has concretely suggested the ability to map any rolls to any nozzles, yet, afaik
But I would be laughing my ■■■ off if H3C can’t.
Let’s pretend you’re printing a blue castle. It has fine details, but it’s big, so you want to use dual nozzle (0.2 and 0.4) printing so it doesn’t also take forever to print.
You only have one roll of blue filament.
How do you print that filament through two nozzle sizes without a switcher?
If the build plate size of H3C will be indeed the exact same one the H2C has, then would it mean that all their build plates will be interchangeable?
I’m mainly wondering about the currently sold out SuperTack plate, whether they will just change the variant name from “H2C” to “H2C/H3C” and it will still stay as “sold out”
 it should have shown the estimated restock date of November 3rd/4th if it was the exact same one and they were planning on making it available for the release of H3C, no? But it’s been sold out on Bambu website ever since I first started looking for it.
Wondering if I should just get the H2C one from the official resellers after we know whether it would match them tomorrow.
It’s almost funny them launching a Flash Sale for these plates when they only have the H2D one available in stock out of all the possible printers, and the earliest the other variants would be available is November 7th, which is way past this Flash Sale :sweat_smile:
Will there be an upgrade path form my H2C to H3C?
Highly doubtful. The cabinet has to grow significantly in depth most likely, but this is just my own speculation.
Absolutely! It’s even a simple two-step process!
  1. Sell your H2C.
  2. Buy an H3C.
Seriously, though, I’m not even sure the bare frame will be common at this point, it looks like everything is radically different on the H3C to the point where it would have made no sense to try to design the H3C to utilize enough of the H2C to make an upgrade path viable.
I would say, you better buy a second roll. When you have to retract and load the same roll alternating between two nozzles, you throw away every single advantage of the H3C over the H2C. You give up the fast nozzle changes, create a lot of poop and print time will grow tremendously.
