Soft, sock-like wrap. Springy rebound, ready to run.
Ultra-soft TPU 75A and 90A, printed in one build on Bambu Lab H3C.
Nov 3, 9AM EST
Nov 3, 9AM EST
Is it me or does this 75a looks like a foaming TPU? If not, you guys are monsters making tool changer that can print with that soft filament is wild, Creality still didn’t deliver their promise on ultra soft TPU for their K3.
@MeshMaster looks like one of your wishlist is coming true ![]()
Is this going to be on a par with the siraya foam ? filaments @Daisylee tried and tested
How come it is 2.75mm diameter?
i think they took this idea from another brand, i saw it last year at formnext (i forget the name), they had increased diameter and it printed at PLA speeds, was pretty impressive
edit/ and as it’s very soft it’s with the exact same hardware of the 1.75mm filament
Good catch. 2.85mm would make it a bit stiffer and possibly easier to feed. Going to guess they are going to have specialized/dedicated nozzles and PTFE tubes for handling TPU of this size.
Sounds like “flexfeed” is their new name for the tool/feed path according to that tpu link.
Interesting how its 2.85mm. I thought we had ventured away from that.
Excuse my naivety, why is TPU a problem for these types of machines (toolhead changers)?
It’s a problem for basically all machines. The stuff is very soft, lacking stiffness, and it’s “rubbery” so it has very high friction in the PTFE tubes. “Pushing” it through a bowden can actually compound the issue. It sticks, bunches up, then sticks harder because it’s pressed against the tubing wall.
In addition it may have feeding issues as the drive gear easily deforms it.
What I am taking away from this is that the H3C will either include, or additionally sell an optional, 2.85mm toolhead(s). I am not sure where the benefits lie for other materials, but for TPU or perhaps PEBA this makes a lot of sense.
That is solution for very soft TPU, due to increased filament thickness, it’s stiffer, so you can easily print with it, hence increased speed.
Would it be compatible with the P3C then? H3C and P3C share almost all of the same parts for their nozzle switching system so I doubt that you can’t print this on a P3C.
Maybe, I think this is where the AMS 3 comes in. If I recall someone thought the larger AMS came with something akin to AMS HT, my guess is a hybrid HT/ TPU Assist for 2.85 only.
More info on then AMS will help fill in the gaps.
It says compatible with H3C only…
2.85mm is an old filament standard, back in the day thats what all 3D printers used. Bambu did not invent anything new, just went back to an older size. You can still buy 2.85mm filament on amazon for older printers and for Ultimaker.
Recrus is the company you are thinking of, they invented an in between size with 2.2mm TPU that can be printed through regular PTFE tubes.
I wonder if H3C will have a dedicated 2.85mm nozzle or if they integrated it some other way such as dual 1.75/2.85 nozzle inlet.
They’re calling this system FlexFeed - so there’s clearly going to be something “to it”.
I haven’t measured a standard Vortek hotend inlet before, but I can’t imagine it’s big enough to let 2.85mm material through.
A “tool head” change swaps the complete hot end including the drive gears, so I would imagine everything from the PTFE tube to the tip of the nozzle is getting changed here.
Ah, well I stand corrected there (that’s a clever cost savings tbh), but the drive gear isn’t so much an issue. It is spring loaded anyways and the extra 1.1mm can easily be accounted for by the mechanism.
