[Bambu Lab H3C] TPU 75A: Our softest yet, for Shore
I use iOS, but I wouldn’t mind switching to android. Both of my pcs run Linux
I was thinking about this filament, firstly i thought that it’s foaming tpu due to matte finish, but on closer inspection it’s not that rought, but it seems they just added some additives to make it rougher and it doesn’t look they changed material. I though this is not poleurethane TPE, but different kind, some TPEs have natural matte finish, like SEBS based. (TPE is a family of elastomer and TPU is one of them, there are many different kind).
If it’s really TPU with additives, it’s actually great news, it gives best wear resistance, strength with tacky and non slippery finish, so they combined best properties of all elastomers, because other kind of elastomers are not that good in this regard.
How did u get access to to this?
I was really hoping they would come out with PEBA. After printing some of that it fits my needs a lot better for most of my rubber projects. PEBA just feels and reacts like normal rubber. On the shoe when it said high rebound I assumed it was PEBA because I have yet to see any High rebound TPU
here is one thing i can’t find anywhere is does the h3c still take 1.75 mm at all, or is every tool on the 2.85 flexfeed path? if it is 2.85 across all nine tools that a completely separate spool ecosystem from every other bambu printer, which would be a pretty big call for a first generation.
I doubt that, this means that they have to double the offer of filaments in the store.
2.85 has basically been abandoned by most because heating takes longer due to the longer distance to the core of the filament.
The added stiffness is good for TPU, but some very brittle engineering materials would suffer greatly from this size.
Yes H3C will take standard filaments. Check the third item they added today. Bambu Lab H3C: Tool Changer. Game Changer. | Bambu Lab
Wondering if all 9 spools in the AMS have the FlexFeed to be able to do multicolor TPU 75A?
Is the bypass the way to utilize the FlexFeed path or is it through the AMS for 2.85mm and the bypass is for harder TPU at 1.75mm?
How many spools will have the bypass? Seeing that the P3C will only have 5 of the seven slots.
Hoping to be able to print “At Least” 5 TPU colors with PLA support in one print.
I don’t really see any real advantage for my workflow unless the H3C has this superior TPU functionality over my U1 and H2C printers. So far the teasers only show 2 colors and one is 2.85mm and one at 1.75mm
the question is i most want answered, and i think it is the one bambu is deliberately not answering yet diameter and hardness are two separate variables, all they have said so far is 2.85 for 75A, but it does not tell us if the other tools stay on 1.75 or the whole machine moves to 2.85 if 2.85 is only the soft path, then standard spools still work and flexfeed exists purely to stop 75A from buckling in the feed tube
In the recent teaser with the watch ( [Bambu Lab H3C] 0.2 or 0.4? Why not both ) they showed printing both 1.75 and 2.85 in the same print job, also combining different nozzle sizes. So it’s definitely not the whole machine but rather an extra benefit.
That settles the main question for me, so 1.75 stays the default diet and 2.85 is the optional soft-material path, existing spools are not orphaned, they just do not feed the TPU tool. And one thing i still cannot pin down is does the 2.85 spool sit on its own feed lane, or does the same hub grip both diameters? If it share the hub, the feeder has to handle two strand sizes at once, that would be the actual interesting part of flexfeed.
But in fact the strap need not be printed in place. But I get the point of mixing very soft and harder TPU. Will be more interesting whether all nozzles can handle the 2.85mm filament. Or the flexifeed only means exactly that the AMS can feed flexible material or is flexible to feed 1.75mm and 2.85mm filament. Because the tube and feeder needs a bigger diameter. Otherwise a combo with the filament would make sense. Also to prevent people with other porinters buying this filament. Guess soon it will be resold on marketpalces.
But it is everytime curious if one company introduce such a change (to mix different sizes). I know Ultimaker uses also 2.85mm filament and according to Google also Lulzbot. So it’s only exotic in the consumer market. But it may absolutle make sense for this very soft material. But maybe this will be the 10th spot on the AMS only for flexible material with 2.85mm diameter.
But then everybody is dependant to Bambulab as supplier for this filament. I guess the market is to small that lot of companies will suplly this.
0 chance tbh. Absolutely 0 reasons to make 2.85mm version of even PLAs, managing stocks will be hell on earth and bambu already struggles to keep just all their 1.75mm(s) in stock :sweat_smile:
Question about the BounceBerry X Trainer, the Multi-material Flexible showcase print with TPU 75A and TPU 90A. How was the 90A fed for that print? Was it from a spool in an AMS 3H slot going through the bypass port, from the external spool holder, or some other way? And which slot or PrintTool did it use? I’m planning a similar multi-material TPU print on my H3C and would like to copy the setup that worked for you. Thanks!
