I think I found a bug in bambu studio,
with a model on multiple plates, and with multiple filaments, if you enable the scraf seam settings for the first filament, it applies if to the others as well, even if its set to none, so if you slice, you will have the scarf seam, even when you dont want it. only way to fix it, is to disable the scarf for all filaments.
