Bambu Studio - What happened to the project section?
Hi.
I am not aware of any of the shelf solutions. I mean within the slicer.
If this is important to you, there are solutions.
The .3mf file is a compressed archive file where your project and the metadata from the Maker World project are stored. So you can access the files and delete the MW project data.
An overview of the procedure:
  1. Make a copy of your .3mf file so you can recover it in case of failure.
  2. Unarchive the file. The software depends on the OS (e.g., Windows - WinZip, WinRAR, etc.)
  3. You will get a folder where files are organised in other folders. In summary, you have assets (e.g. pictures, models, settings) shared and “interpreted” by the slicer through XML files. So, in your case, you need to edit which data is transmitted by editing the XML files.
  4. If successful, you use the same program as in 1 to compress the folder into an archive file (.zip, .rar) and change the file extension to .3mf.
Regarding step 2, I cannot give you a standard solution as it depends highly on shared content. Just do one thing at a time and try again if you fail. If you are still interested in doing this, let me know, as I can share further details on the procedure.
Thanks. I’ll give that a shot :slight_smile:
This is what I found out today. If you download an 3mf file and it is filled with project data, pictures and even a different name on the “print profile name” than what you are currently doing with that file and just want to change it, the fastest way is to upload it to Bambu Studio as “private” with the name you want then download it back to your computer. It will clear out all the old project data and keep all your settings and profiles. Now when you go to print it will be called the name you gave it. Then just delete it off your profile in Bambu Studio online.
Assuming you mean Makerworld?
Welcome to the forum!
Yup my mistake and thanks
Clean Project Info from 3MF Files
Here is the ■■■■■■■■ way to wipe project information from a 3MF file:
MODEL="model.3mf"
cp -n "$MODEL" "$MODEL,bak"
mkdir -p 3D && unzip -c "$MODEL" >3D/3dmodel.model
${EDITOR:-vi} 3D/3dmodel.model  # Remove and adapt attributes, but know what you're doing
zip -d "$MODEL" "Auxiliaries/*"
zip "$MODEL" 3D/3dmodel.model
# Load into Bambu Studio and check the "Project" tab
Not for the faint of heart! I might write a small Python script doing this.
It’s been more than one year, any news on this feature?
There have been no Project tab changes in Studio, because it works with Makerworld, just as Bambu wants.
If you want a similar feature for your own private projects, Orca Slicer uses that tab to provide some ability to add pictures, spreadsheets, PDFs, and text files to your .3mf project files. The feature needs some polishing, but I don’t think it is a high priority for the developers. It was not mentioned in the release notes when they made the change.
I find it a little bit limited, and not worth the effort just to make the Project tab look pretty. Since a .3mf file is just a zip archive, I open mine with a zip utility (7-Zip, Winzip, WInRAR, etc.) and add whatever files I want. Usually, I include a copy of CAD design files, maybe related web shortcuts, etc. A note alerts me to look inside the .3mf:
Hi @VEFvan,
Welcome to the forum.
I also do something similar to @lkraus by adding photos, BOM, etc, to the .3mf.
Yet I still miss the GUI, so I was trying to find a straightforward way to edit the pointers for the added files so that I could see them in BambuStudio. Yet, I wasn’t successful as many times it failed, and I didn’t have the time or patience to find the cause.
Orca Slicer seems to be the best you can get currently.
You can also upload your files to MW and add the required info. That way, your project files will be shown in the project section. There is no need to share the file, as you can mark it as private. I tested this months ago, but I do believe it still works.
Any updates on the Project Tab???
Since the question was asked and answered three days ago?
Just trying to keep this topic active. I can not upgrade firmware until this feature is working. The cancellation of the Engineer build plate is putting the heat on me to upgrade.
The Project feature in Studio is working exactly as Bambu wants, so I would not expect it to ever return to the pre-Makerworld days when we could edit project information locally.
I don’t understand why it prevents you from updating firmware. Or why the engineering plate is involved.
I use the Project feature to record the part name, print quantity & part number.
The Bambu X1 printer then displays this information for the operator.
I use the Engineer plate and this plate has been discontinued and therefore may be removed from future slicer firmware.
This is how far I got until now:
> te3mful.py Spool_Stand_with_Braces.3mf --inspect
{'Application': 'BambuStudio-01.09.03.50',
 'BambuStudio:3mfVersion': '1',
 'CopyRight': '[]',
 'Copyright': '[]',
 'CreationDate': '2024-09-11',
 'Description': '<p>Spool Stand designed for the bambu labs refillable '
                'spools. For storing spools upright on a shelf to stop them '
                'rolling away. <br>Each stand has slots for an '
                'additional spool so the stand system can be extended. '
                '</p>'
The plan is to be able to render a markdown file into the description, and add any pictures that share the basename of the 3MF file as aux files. Will be on github when usable.
From someone who has been there, it isn’t straightforward. There are three alternatives, and the one you’re following is the hardest.
I had success a few times, but most of them failed. The failure wasn’t a big problem, yet I couldn’t find the cause.
I stopped when I found myself reading about the 3MF Consortium.
Upload your model to MW (you can make it private) with the necessary files. The result is a 3mf file already configured.
Alternatively, use OrcaSlicer for the purpose. The project section is editable and works as in the early versions of the Bambu Studio.
Let me know if you have any questions about how to do it.
Edit:
Are you sure? I still have a few engineering plates in mint condition, and I believe others have it, too. I doubt that BL would block a user’s access to their product.
Does the latest version of OrcaSlicer allow population and edit of the Project Tab information?
Yes.
What do you mean with “allow population”?
Add data, you know…pictures, author, model name … all the blank fields under the Project tab.
This information is then listed on the Bambu display for the different parts on an SD card.
The question is…Does the latest version of OrcaSlicer permit adding and editing part informtion under the Project tab?
Yes @uman.
The project section in the latest version of Orca Slicer entails all that.
Not sure. I never looked at the Bambu printer display for this info. But if the feature exists, it will also show the information you edit on Orca.
