Bambulab P1S Enclosure temp
Hey guys, i order the upgrade to P1S for my P1P, and i was wondering if everything is ok with it when it comes to temperatures.
I installed a thermometer inside it and when printing with SUNLU PLA META with nozzle at 210°c and bed at 65°.
The temperature in the enclosure is 40° when printing with the values mentioned above. Outside, the room temperature is 28° - 31°.
Is the value inside the enclosure ok at 40°? or should it be lower?
With PLA, open the door and the lid, otherwise it can lead to blockages. The same applies to PETG. Close everything only with ABS, ASA etc.
My AMS sits on top of my P1S so I only open the door about 2 inches. Printing PLA+ and no issues so far.
If the upgrade includes the P1S cabinet fan then you don’t need to open the door. The purpose of the fan is to control the temperature. You can set the temp from 1 to 5, whatever that means.
Edit: The 1-5 setting thing is apparently wrong. In the filament setings you can specify the chamber temperature directly in degrees centigrade. It must have a sensor with a feedback loop.
Yes the upgrade contains everything about the P1S. So it does contain the Auxiliary Part Cooling Fan.
I didn’t know we could set the temp. I’m going to check it out!
So far i’m printing Smaug and the print is going freaking well so i don’t know if i should worry or not.
I want to buy an AMS in the future. And i have the printer in my bedroom since i can’t put it elsewhere in the house. So i if i open the door, it gets freaking loud.
If the prints come out good with the 40º, then i will always keep it close xD
Wait, where’s this setting for chamber temp?
is not visible with me, have installed the latest firmware and bambo studio. The P1P has been upgraded to P1S.
Today I received an answer to my question about temperature regulation for chamber temp.
From support@service.bambulab.com
It is controlled based on the temperature of the heated bed.
The G-code for controlling the case fan is as follows: M106 P3 S0~S255 (S0: off; S255: full speed - 100%)
(Controlled by the temperature of the heated bed, higher temperature results in higher fan speed, lower temperature results in slower fan speed)
Nice thank you! I wasn’t aware of that feature. I am very curious if it actually works though since there isn’t a chamber temp sensor located anywhere on the P series. (That I am aware of) Interesting!
Nice! That is very insightful. I think i will try in the future to mess with the G-code to create some sort of profiling. To change the values. Certain values for summer and other for winter. I guess this will be possible ?
Just use the Cool plate and you don’t need to open anything printing PLA.
Does the cool plate change a lot in terms of adhesion to the plate ?
I only need to put the glue on it and it runs at the same temps and everything like the textured pei plate ?
It changes a lot about temperatures it runs at 35° instead 90° of textured PEI so everything is cooler and PLA likes more the cool than the warm and you can keep everything closed.
You need glue and the adhesion with it is really strong (I suggest the liquid one), I would say more than textured PEI. Of course you won’t have the textures, it’s all flat.
I’m totally digging that suggestion! I’m going to get a cool plate and try it out. Thanks a lot for the suggestion bro
You are welcome! Happy printing!
I also installed the P1P to P1S upgrade kit which did include the cabinet fan but I don’t remember installing any sensor. The chamber temperature on my printer shows nothing. I am wondering what I need to do or get to have this feature implemented. Any help appreciated!
Welcome to the forum.
The P series does not have the chamber temperature sensor or option. Only the X series has this.
Ok, thank you. So it seems that the cabinet fan included in the upgrade kit is not being used. I guess the solution given by support to willem has to be at the level of filament g-code. Maybe set the fan speed to a specific value when printing PLA, for instance. Maybe ASA, ABS, etc. keep it off.
