I got sick of always having to worry about fingerprints and having to clean them when I’m not careful enough so I recently bought some rubber gloves. It is much better.
I’ve been running into a similar issue. I’ve had my x1c for a couple weeks now. The first couple prints held nicely but then each time at least one of my group prints would pop off. I’ve washed it with soap and water, rubbed it down with ISP, glued sticks work ok but still not 100%, I’ve also tried hairspray and also no good. I’m printing PLA, I have my bed set to 60c, and as soon as one piece of the group fails the print head will slide it into other pieces which start knocking them loose as well. The ONLY thing I’m thankful for so far has been the SKIP feature in the software so I don’t have to start completely over when I’m 24+hrs into a 72hr print.
I have not found a need for this as I would probably leave additional fingerprints whose oil the ISP would then evenly distribute across the plate.
You can improve glue stick performance by taking a moist-to-wet cloth to disperse the glue evenly across the build plate. Once dried, it will leave a very thin, very effective glue/release film across the build plate.
I assume you are using Brims on the troublesome parts?
I get this a lot if I’m switching between different types of filament. If I switch to a different brand, I take a paper towel that is slightly wet and wipe the plate. It helps a lot with this issue.
Interestingly Wham Bam says use ISP 98 to clean the carbon plate. Recommend soap only after trying that.
I was skeptical, especially since I’ve been having issues with that plate.
However, it is all you need, other than a clean paper towel. I used to use a microfiber but have since learned they can leave lint behind and don’t always get everything off. I also wonder about fabric softener or detergent from washing causing issues. That comes from knowing you should use soap, when you do, that has no perfume or lotions added.
Well, my experience is limited to the Bambu plates (and the ancient Tevo stickers).
I have had the best of success on the Bambu plates just with dishwashing liquid, water and, very occasional, a good scrub with the bristles of a dishwashing brush. Only a single case of needing to use steel wool on a textured plate to date. Still not sure if I just removed contaminants or also re-lifed the surface by again exposing original plate material.
I also heard about the microfibre being able loose threads but I’d expect that I’d see them. So far, my experience has been that as long as there’s no non-adhesive film on the plate, printing is usually fine.
PS: The carbon pattern leaves an imprint on the part, right? I have 2 of Bambu’s 4 holographic build plates and yeah, I clean them muuuuch more carefully than the smooth and textured plates. Dishwashing liquid, water, a cloth and a looot of gentle stroking rather than the more robust scrub my other plates get.
No, this is real carbon fiber. Just like parts molded with it the plate is carbon fiber in resin. There is no texture or design left on the part, just smooth.
Oooh, nice
I was not aware of Carbon Fibre plates. What are the advantages?
Oh, and depending on the resin used, it may explain why water is not recomended. A build plate with even minor changes in its thermal properties (due to water uptake for example) could become frustrating.
There’s a vid and link in that thread.
I had reliability issues with a glue stick then discovered a spray glue for filament printers at my local electronics store. It seems to work a treat and doesn’t leave any marks. Cleans up with just water.
Yes they are great printers till they are not, I bought 4 P1P printers and one the printhead is always too high and the print fails, had such a clog that it cost me 2 hotends, Bambu Support is absolute garbage, may dispute these purchases with my credit card provider, complete ■■■■. I did everything they suggested. really pissed I wasted my money on a non user friendly printer, should of bought the Creality K1 or K2, at least easy to adjust the z axis , seems these printers are disposable as not user friendly with bed adhesion, I am so pissed at bambu customer service, just ■■■■ if you can;t fix it, the other 3 printers do print the same file properly but the one, waste of money for me, regret selling my other 12 printers to supposedly upgrade, they are good till they are not.
Welcome new user! Glad you could join us!
I have been having issues lately with precisely this.
Never really thought about soap and water. Fixed everything!
Thank you @JonRaymond! I tried all kinds of calibration and settings, cleaned the build plate every time with IPA, and couldn’t for the life of me figure out why my prints were failing (they looked exactly like @Mugen89K 's print). I washed the build plate with soap and hot water and poof, my troubles vanished!
Hey everyone, I’m also having an adhesion issue.
In my case, it seems like the filament isn’t being pressed firmly enough into the bed.
I’ve already replaced the entire extruder, including the LIDAR unit, changed the build plate, manually leveled the bed, and fully recalibrated the printer — but the issue persists.
It really seems like the problem is coming from inside the printer itself.
P.S. I have multiple Bambu Lab printers, and the same files print perfectly fine on the others.
This specific printer has around 2300 printing hours on it.
This is Peter, thank you John for the very kind words. We do take our products seriously with lots of pride, we feel bad if there’s even one person who is having issues and typically have ideas of how to find the solutions and we like to work 10 one with our customers. I really appreciate you sharing this. It means a lot to us that somebody recognizes How far we want to go to make sure our customers are happy. Thanks again.
microfiber cloth like the stuff u clean glasses with might get rid of fingerprints, but how would you get the glue off if u use glue?
Welcome to the forum!
This is Bambu’s recommendation for cleaning their own glue off:
Basically the normal plate cleaning routine but letting it soak first if the glue is dry…
Great idea, thanks for the info
