Best/worst re-spoolers 2024? Please share GOOD & BAD recommendations
I am looking for a 3D printed re-spooler contraption that works reliably and spools filament onto a second spool as neatly as a manufacturer’s spooling machine. Is there such a model published that works better than a Pastamatic?
Please share your GOOD and particularly your BAD experiences, including re-mixing mods.
These models use a lot of filament to print, and I read countless posts by people disappointed by the results after their efforts to print a large device. The most downloads clearly does not imply the most efficient re-spooler.
Thanks
The best I could find was the Jarvis Winder. And even that doesn’t seem to work as good as I would like it. The newer Jarvis Pro Winder looks better but isn’t open source.
So I fear there currently isn’t a really satisfying solution available for hobbyists.
Thanks. I’ve updated my request to say I’m looking for a 3D printed spooler model - something like a Pastamatic, but hopefully better.
The Jarvis Pro Winder is a 3,300 EUR product.
Yes Jarvis Pro is not for personal use. But Jarvis non-pro is open source, so you can build one yourself at much lower cost.
I don’t think that there exists anything really useful that you can just print.
You need to fine tune the winder to the exact width of the spool and the diameter of the filament. You also want controlled constant tension. That is just not possible with a purely printed device but necessary to achieve the quality of winding you are asking for.
Even the Jarvis Pro is possibly far from what manufacturers use. The predecessor seems to work but to have problems with tension control. Building a Jarvis non-pro is probably the closest you will realistically get to neatly rewound spools.
Thanks @Alex_vG - I found the Open Source plans at GitHub - QiTech-Industries/Winder: Filament winding machine powererd by ESPdruino.
This looks great but I was hoping for something simpler - kinda like a Pastamatic or V3 Spooler or Bambu Lab Filament Spool Switcher & Winder that spooled the filament more precisely on the target spool.
Every one of the mechanical spoolers has multiple remixes that claim to solve various problems, so it is tricky to find the most efficient model.
Combination of this:
https://www.printables.com/model/407688-bambu-lab-p1-x1-x1c-x1cc-filament-spool-switcher-w
and upgrades from this guy:
https://www.printables.com/model/479022-stand-for-bambu-lab-filament-spool-switcher-winder
I tried a couple others and I don’t like the lead screw ones. They don’t wind tight enough or don’t work at all and bounce around. Overall I’m happy with this respooler.
I’m also looking for a respooler.
But most, if not all of the printable spoolers, are not adjustable to the spool width.
Most systems seem to be designed to work on a full revolution/sequence of the rod/gear before going back. So this just gives a fixed spoolwidth.
The Bambu winder seems a bit more adjustable. But all is fixed to this full gear rotation. Although it should be a bit customizable with adjustable teeth. But seems the top gear is holding everything firmly in place and it’s not designed for easy switching/replacement.
The V-spooler looks great, especially because it’s compact design. But it’s completely over designed, needs a lot of resources and I actually don’t like the rod either, which is also not customizable.
While it would be nice to have something as accurate as the machines the big filament suppliers use, I think it’s possible to get something as close as to make no difference, though doing it without electronics would be very difficult indeed.
So let’s consider a few things:
The exact width of the spool could be entered or supplied by a sensor, perhaps lidar.
The diameter of the filament, I think, can be safely assumed to be 1.75mm.
Constant tension could be supplied by monitoring the takeup reel motor current. Alternatively, rpm of the takeup reel motor could be used to adjust the tension by moving a metal disk closer to or farther from, magnets mounted in a printed disk .
As for positioning the filament guide to wind it onto the right place: If we know the width of the spool and know where the edge is, we can set that value for the number of steps for the following.
A stepper motor could be used to move the guide 1.75mm per revolution, reversing at the end of the travel, and auto-correcting at that time.
I offer these ideas in the hope that someone (or a group of someones) can come up with an implementation and produce it.
I’m too old to relearn Arduino coding.
The guys from Jarvis winder did exactly what you describe and quite a bit more. And they even made it open source.
In the second version, instead of measuring tension by the motor current, they use a lever, which seems a far better idea to me. But I guess, the open source version is good enough.
So what you ask for is already available, you just have to follow their build plans.
I did print this one, I’m happy with the results so far. The only hiccup was when I broke the axle with my drill being too strong (while the original filament got stuck until i disentangled it). I printed another one at full strength, made sure to stay gentle on the drill, it went ok. The manual handle goes fast enough though.
I screwed both part on a wood board and it’s now there stored on a shelf.
Just curious, which one is “this one”?
I think he printed the winder from the ExtremeElementz links from April 4th
I have been hoping some affordable, pre-built, non-3D printed filament respooler would come out by now, but it still has yet to manifest itself. Ive tried several of the most popular 3D printed options and they can work a few times before their design issues cause more problems than they’re worth.
That said, this is the first time I have read about the Qi-Tech Winder. Its a larger footprint than I would like, but at least looks stout/solid. Has anywhere here built one? What was the cost for parts in the US and how has it been running?
I made the respooler designed by Miklos Kiszely but had a lot of trouble with the oscillating carriage gear coming loose and remodeled all the parts to be 5mm thicker (the shaft needs to be 15mm longer) and the gear to be 2% wider to tighten up the mesh. I did have to file the 2 teeth on the ends to provide enough clearance and it seems to be a bit better now although I’ve only rewound 3 spools so far.
Some of the ones I found did not work, started to work when mounted securely to a base, and using glue or screws to increase rigidity.
So my answer is really, all the popular ones with high downloads will work, and if they don’t just screw them down until they do.
I’m working on a respooler focused on easy build, for Bambu spools, here is a recent test run:
And another variant
The main engineering challenge currently is on getting nice and constant filament tension when trying to respool within 90 seconds. I think a longer PTFE tube with a bit of a curve forced into it might be the simplest option.
I’ve tried putting an air brake on the donor spool and it does something but it’s not consistent enough for different spooling speeds. Any other friction based system will need a wide contact area to not melt any printed plastic, and it’s challenging to do this elegantly…
The solution came to me in a daydream:
I’ve tried several different models with most requiring some sort of added hdwr purchase requirement to assemble. To me that was unacceptable as I came to envision being able to print everything I needed for that job.
Found one that fits my needs and does NOT require buying anything extra. Just add a little sticky grease to the gears after assembly and this winder gets the job done easily, quickly, and most of all, neatly.
I don’t know the designer so my opinion of this device is unbiased. I’m only offering my opinion after using it.
looks like a remix or another variation of the pasta. will try it out… seems like its more compact than the KYZ design since. i think i saw one where the donor spool was on top of the receiving spool. forgot the designer. but it was also another remix of pasta. wonder if the vertical one is better just coz of compact-ness sake. since both are remix of pasta.
also… would using PTEG be a lot better than using PLA in printing the spooler? sorry for asking… new in the 3d printing world. haven’t used PTEG yet.
