Broken Filament Sensor - Not Available on Bambu Lab Store
In troubleshooting Cutter Lever stuck issue, where Wiki suggests removal of connectors, the very delicate ribbon cable on the filament sensor tore as I removed the harness tape which held it to the upper portion of the extruder toolhead.
In looking at the store, Bambu sells it individually @ <$15, but it is unavailable.
Are there any other sources?
I’m in the midst of a project and would buy a complete toolhead or other bigger component if it’d come with an filament sensor.
Is the cable available individually? It can be removed from the board on the side of the sensor.
Thank you,
Doug
The whole extruder is a building-group.
The easiest way to fix it is, to buy a complet extruder.
I dont think, Bambu sells the little cable.
I think you mean the P1P/P1S-Extruder-Set.
you just have a small piece inside it, so just take it out and dump out the piece
thank you! I feel a bit stupid. I didn’t realize it was part of the complete extruder. I bought two, so now I’ll have a spare. and maybe a second spare when support gets back to me. Or I’ll buy the filament sensor when it becomes available for separate purchase.
