Can a US market H2D be run on 220V?
Tell that to Bambu
Electrical Requirements Voltage 100-120 VAC / 200-240 VAC, 50/60 Hz
Max Power* 2200 W@220 V / 1320 W@110 V
Average Power 1050 W@220 V / 1050 W@110 V
Yes, 120 has been the US standard since 1984.
110 and 220 are terms that are in use today as common terms even if not technically accurate but were historically.
And if I measure the the actual voltage at a receptical in my house it will usually be 117 or less because of line drop.
I was not intending to give “electrical advice” per say but pointing out the actuall challenge of the Hertz difference between the US and Europe. I have lived in both the US and Germany and know that there is a potential to damage equipment even if the voltage is converted properly.
But thanks for the concern.
