Cannot create full brim after using brim ears
Hello, this is my first topic :slight_smile: and I’m hoping someone can help me.
I cannot get a standard or full brim to appear in the slice preview.
I first enabled (and printed) this bed adhesion test piece using the new brim ear feature which worked very nicely. The first screenshot shows the automatically generated brim ear. Note that Brim type is set to Painted.
I then wanted to print with a full brim so I can compare results. I removed all the brim ears and changed the Brim type to Outer brim only. After slicing, the brim does not show in the preview.
Screenshot 1: Automatically generated brim ear.
Screenshot 2: Standard brim, nothing in preview.
I’ve checked and there is definitely no brim in the line type list like in this post:
Is this a bug or have I missed a setting somewhere to use the standard brim?
Hi @inlex,
Welcome to the forum.
I followed your instructions (different part), and I couldn’t replicate your issue:
Bambu Studio v1.10.1.50
OS: Windows 11
Can you recheck and provide further details to find where the glitch is?
Hi @JayZay, thanks for taking the time to try and replicate the issue. :slight_smile:
I think I’ve figured out what is happening.
When adding brim ears, a little warning appears if your brim type is not set to Painted. Clicking the Set the brim type to “painted” text changes the brim type of the Object to Painted. I expected it to change the Global setting. It was only after looking in the objects tab that I realised what was happening. This makes sense now why the global setting was being ignored and I was not seeing any brim.
I wonder if clicking that text should offer you a prompt to choose to set the brim type to painted globally or for the object that the brim ears are being added to.
So I guess this was just user error :blush: I’ve marked this as the solution.
Good morning.
I am having the same issue.
The ears show up when you click the brim ears button, but when I click preview, they vanish and don’t print.
I have set the type to painted, but it doesn’t make any difference.
I tried to add picture but cant without an error
